WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby Battwell » Wed Jul 20, 2022 2:06 pm
hi shad.
this plugin works great in the main. (have been using it while waiting for cnc drive to sort the ucr201 plugin bugs up until now)
the only thing that gets annoying is if a soft limit is hit it tends to kill any movement-after soft limit warning is cleared. often requiring the dongle to be removed and re seated.
no button press combinations seem to re instate movement- however step and continuous buttons do work.
is there anything you can do about this?
Postby cncdrive » Wed Jul 20, 2022 11:10 pm
We already sorted out the UCR201 bug which caused the probing issue.
I don't know there is any more problems?!
That fixed UCCNC version I've already posted and can be downloaded.
Postby qb6sagr » Thu Jul 21, 2022 3:15 am
Shad, and all who contributed to creating this plugin, you are certified legends. Thankyou very much!
Cheers, Rowdy
qb6sagr
Postby Battwell » Thu Jul 21, 2022 10:41 am
cncdrive wrote:We already sorted out the UCR201 bug which caused the probing issue.
yes- tested the new version last night. seems ok now.
i swapped to the other pendant while waiting for the bug fix for machine sales customers as couldnt have it throwing exeptions or killing probing for them.
i have to order more controllers next week.
Postby shad » Thu Jul 21, 2022 6:46 pm
qb6sagr wrote:Shad, and all who contributed to creating this plugin, you are certified legends. Thankyou very much!
Cheers, Rowdy
:D
Battwell wrote:hi shad.
I will check it, thanks.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby woffler » Fri Aug 19, 2022 12:50 am
Well i bought one of these pendants and i am having a problem trying to get it to recognize it ,I have read thru a bunch of these posts and tried about everything i can think of .
I never get a icon in the task bar or any where else, I do get a connection in the plugin window but it does not pick up the DRO'S or any movement just shows zeros .
It shows up in in USB connections but I can get nothing from UCCNC I am using a 2022 screen set and I do have a PS-2 pendant and it works I was trying to get rid of the cord .
I even went to the product web sight and downloaded the DLL. file and the shuttle pro macro but no dice ,I also tried the test macro for the WHB04B-6 but for some reason these are not showing up inside the the configure macros window in the profile i have a AXBB-E board and a UCSB B/O board and servos on 4 axis .
Any help would be greatly appreciated
woffler
Postby Battwell » Fri Aug 19, 2022 9:10 am
send me email address- i will send the .dll for wireless version.
too large to add as a file here
Postby woffler » Fri Aug 19, 2022 2:40 pm
Here it is (woffler1@gmail.com) thanks for helping me to resolve my issue .
woffler
Postby woffler » Mon Aug 22, 2022 7:57 pm
I still have not been able to get this this plugin to work I am sure that I am not getting something right here but I am not sure what is it maybe because I have the 6 model .
woffler
Postby shad » Sun Aug 28, 2022 7:06 pm
The plugin should work with the 6 axis version too.
Please remove all unused plugins (especially those that work via usb) and try again.
Enable plugin in the Plugin Config menu.
Also there is a some problem (UCCNC halting) with plugin for machines based on the WinXP... Still have not time for find why...
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
