WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby Archy » Sat Sep 11, 2021 2:24 pm
Hi, Is the 6 axis xhc-whb04b-6 compatible? Ready to buy one for my axbbe. And do all buttons work?
Archy
Postby cncdrive » Sat Sep 11, 2021 4:28 pm
Buy a UCR201, it is 6 axis compatible and is manufactured by us. http://cncdrive.com/downloads/UCR201_manual.pdf
Postby Mr.Hotwire » Sun Jan 16, 2022 6:37 pm
shad wrote:Hello!
For those who want to test out the WHB04B-4 pendant plugin.
Please let me know if there is a bug's.
Not sure if this has been brought up before.
With the pendant connected, I cannot change the movement ratio via the screenset.
I can click on the + and - all I want, It scrolls up and down just fine, but then reverts BACK to the setting set on the rotary dial on the pendant.
Mr.Hotwire
Postby Fanmain6 » Thu Feb 24, 2022 12:01 pm
Hello everyone!
I am in a terrible trouble: I've purchased a 'LHB04-4 ' controller instead of WHB04-04. :oops: Is there any chance to use it with UCCNC? I have UC300-5441. Does a plugin exist for it somewhere? Or any other suggestion?
Thank You for the help! George.
Fanmain6
Postby Daywalker » Wed Mar 23, 2022 7:02 pm
Fanmain6 wrote:Hello everyone!
Same here, there are no way to Use the Cable Version from the Hand Wheel ???
Regards from Germany
Udo
(UC300ETH & UB1)
[Yeah, I use a Translator ;-) ]
Daywalker
Postby Daywalker » Wed Mar 23, 2022 7:32 pm
Ok, the Cable Version Works, but you need need to Activate MPG Cont. or Single or Multi in the "Pop-Up" Menü.
Is there a way to Stay this Activated ?
Udo
(UC300ETH & UB1)
Daywalker
Postby DavoH » Sun Apr 24, 2022 9:55 am
Hi all,
I have the USB cable version of this pendant (LHB04B-4 I believe).
I downloaded and installed the DLL (kindly supplied by Shad on Aug 10th 2021) and found that most things work - after I've enabled it via the pop-out window for MPG thingy.
However there are no macros for it, pressing those buttons doesn't give any results.
Using the Functions button all functions work fine!
If we could get some macros working for it I'd be a very happy camper. :P
However, I know nothing about programming DLL's or macros or anything like them, so can anyone spend a bit of time to help out please? :)
There are probably lots of these cabled pendants that could be used by others too, I used mine heaps with Mach3 and it's great.
My UCCNC software is version 1.2113.
Many thanks,
Davo.
DavoH
Postby valhallaCNC » Mon Apr 25, 2022 12:40 pm
I just ran across this thread the pendant looks interesting. There is not a lot of currant activity on this thread. Is this plugin finished now and fully functional ? Are there any outstanding issues ? What is the latest date on the plugin? Thanks
valhallaCNC
Postby valhallaCNC » Fri Apr 29, 2022 3:28 pm
WOW...This must be so good people are speechless...........
valhallaCNC
Postby shad » Fri May 06, 2022 9:51 am
DavoH wrote:Hi all,
Many thanks,
Davo.
Hello Davo!
Can you explain about "no macros for it"?
May be you have to assign some macro for macro buttons in the plugin settings? The plugin settings window will open after the left mouse click on the remote control icon in the Windows taskbar.
It is possible to assign a macro to each button.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
