XBox 360 plugin problems
Re: XBox 360 plugin problems
Postby Greolt » Sat Oct 28, 2017 2:23 am
Further to this, when you get a chance to look at the plugin.
I still find the step distance selection with the RightX to be flakey.
Would it be better to have right push of the stick toggle the top two values, and left push toggle the lower two values.
Right push could check to see if one of the top two values is already active and if so toggle value. If one of the top two values is not, active then select the first of the two.
I think this might work better than the half/full push thing.
Greolt
