MODBUSEZ Plugin
Re: MODBUSEZ Plugin
Postby alex_s » Thu Nov 30, 2017 10:47 pm
thanks for this plugin, i'll check it our with a powtran 9130 tomorrow, its a very good cheap VFD with proper vector control and torque boost :)
if you need this is the english manual
https://www.klibo.de/fileadmin/klibo/re ... glisch.pdf
alex_s
Re: MODBUSEZ Plugin
Postby Dan911 » Fri Dec 01, 2017 4:13 am
alex_s wrote:thanks for this plugin, i'll check it our with a powtran 9130 tomorrow, its a very good cheap VFD with proper vector control and torque boost :)
Hi Alex,
The manual you linked should make it real simple and easy to get you up and running quickly. I snipped 2 sections that's needed for your Modbus parameter's, you probably already seen reading through but thought I'll post for others.
These are the settings you need to input into modbusEZ configure using the first option in manual/snip for frequency, if you choose to try second option you will need to check the HZ*100 box to increase the frequency range. I added this feature and you can download at bottom of this post. The Amp setup is in configure window but not implemented into code yet, I will post new and last version in a couple of weeks with updated manual if my Time allows.
Hope you setup goes smoothly,
Re: MODBUSEZ Plugin
Postby Dan911 » Fri Dec 01, 2017 4:23 am
Hi Alex,
The attachment 9100.JPG is no longer available
The attachment 9100 freq.JPG is no longer available
The attachment ModbusEZ.JPG is no longer available
oops, here's your plugin
AlexMEZ15.zip
(12.68 KiB) Downloaded 976 times
Re: MODBUSEZ Plugin
Postby alex_s » Fri Dec 01, 2017 7:54 am
Wow thanks :D ,
yeah had already printed the Register sides for setup, but awsome man, i get up and waiting for the post man and you present me with a rdy solution :)
Much appreciated, will report back as soon as the postman drops it off.
alex_s
Re: MODBUSEZ Plugin
Postby Dan911 » Fri Dec 01, 2017 1:22 pm
Hey Alex I forgot to mention one more important setting, if using the settings I posted for ModbusEZ you need to set F0.02 to 1 ( 0.1HZ)in your VFD.
ModbusEZ default HZ resolution is 0.1HZ and to change to 0.001HZ you need to check checkbox in spindle setup. To put it simply and clarify what this is doing is basically just adding a zero to end so frequency sent falls in the right decimal place of VFD. All VFD's frequency setting needs to be sent in Hex and decimals are not used.
Re: MODBUSEZ Plugin
Postby Battwell » Sun Dec 03, 2017 4:53 pm
im glad you posted those pictures from the manual.
i managed to set speed on my ecogoo by setting the keypad frequency register using modbus (but keeping the drive option as- use keypad frequency instead of using communication setting)
still cant find any way of making it run without using terminals. (tried setting the inputs by modbus - which reads back ok- but doesnt start the drive)
to be fair- il be using the terminals, but id love to know how they designed this thing to work by modbus!
Re: MODBUSEZ Plugin
Postby Dan911 » Sun Dec 03, 2017 9:10 pm
Battwell wrote: but id love to know how they designed this thing to work by modbus!
Me Too! They provide a 35++ page manual and not a sentence on Modbus setup, had to be frustrating. Looks like a nice drive though with a lot of features.
Re: MODBUSEZ Plugin
Postby Battwell » Mon Dec 04, 2017 12:14 am
It seems pretty good on bench test
It's a special- 220single phase in 380out
Not much choice on models that can do this!
I have the hy t series too. I bought this one as I can get it inside the cabinet instead of hanging on the outside like my hy.
The funny thing is-the tech dept couldn't tell me how to do it.
Re: MODBUSEZ Plugin
Postby alex_s » Mon Dec 04, 2017 7:41 am
i hope the postman comes today, so i can test it :)
alex_s
Re: MODBUSEZ Plugin
Postby Battwell » Mon Dec 04, 2017 10:49 am
these settings work with ecogoo9100 to set frequency only
i still cant work out how to get it to run- as nothing in the manual! ive spent way too long on it!
frequency source parameter p0.01 must be left at use keypad (0) not communication settings (7)
