andileibi wrote:Thanks for the Info, I think I'll buy a xbox 360 controller.
Anyway, I can imagine that it would be cool using a 3DConnexion Spacemouse to steer a cnc router...
andileibi,
Last thing I forgot to mention when you tried the XBox plugin... did you check the box to 'call startup' box in addition to 'enabled' on the plugin config page before restarting? If not try that and see if your generic controller works, it is required the plugin starts w/ UCCNC to find the controller initially.
If you do that and still it doesn't find the controller, then you can be sure it is a compatibility issue and you need a controller that behaves like an xbox control.
Regards,
