HB04 pendant
Re: HB04 pendant
Postby drumsticksplinter » Thu May 14, 2020 1:05 pm
Would this likely be a bug with using the AXBB controller, or something I am doing wrong in my setup? Thanks ;)
drumsticksplinter
Re: HB04 pendant
Postby drumsticksplinter » Sat Jun 27, 2020 1:18 pm
Just wondering if anyone is able to look into this from cncdrive please? Is it just my pendant or would this functionality be the same with any pendant using AXBB? Thanks
drumsticksplinter
Re: HB04 pendant
Postby cncdrive » Sun Jun 28, 2020 3:58 pm
Dezsoe,
Please test this... thanks.
Re: HB04 pendant
Postby andreiir » Fri Jul 03, 2020 1:22 pm
If i select a axis , and use mpg count , if i rotate encoder wheel , and move the rotary switch to another position , then it doesnt stop from counting and axis go until softlimits are reached or i press cicle stop or reset , or i switch the roatary again on axis that i was before .
On mach 3 it doesnt make this bug , only on uccnc plugin .
andreiir
Re: HB04 pendant
Postby drumsticksplinter » Fri Aug 21, 2020 12:05 pm
Hi, it’s been a little while, did this ever get looked into by cncdrive? Would the UCR201 pendant work with the axbb-e without having the bug I’m experiencing, or is it just my mpg? Thanks.
drumsticksplinter
Re: HB04 pendant
Postby andreiir » Wed Sep 30, 2020 8:43 pm
I agree , if i put a value , it goes totaly wrong , it doesnt make steps like mach3 , it goes more steps than it shuold .
And if i save the value , next time i open the soft , it resets , and goes to 5 .
andreiir
