Variable that will be available in the plugin and macros
Postby shad » Sun Oct 09, 2016 3:21 pm
Is it possible to add ability to declare in the plugin any register (int or bool or double variable) which will be available in the macros. Just any time we need to check any plugin variable in the macros.
For example declare
REG   n_SystemIsBusy;  //declare register
RegRegister("Neuron", "n_SystemIsBusy", REG_TYPE_GENERAL, &n_SystemIsBusy);  //Add register for the Neuron device in the UCCNC
Then get the value in the macros
bool res = GetRegValue("Neuron","n_SystemIsBusy")
Balazs, what you think? It's will be useful in the future?
Also I see Getvar(int varnum)/Setvar(double value, int varnum) functions. May be this is what I say? In this case how to declare Variable in the Plugin (which will be available in the macros, for example variable #1)
Thank you!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
