Webcamera Plugin
Webcamera Plugin
Postby zymurgy42 » Mon Feb 27, 2017 2:38 am
Is there a shortcut method to get the webcamera plugin up and running. Currently I go to configuration > Plugins > Webcamera > show.
Could that be called by a macro? If so, guidance appreciated.
Gordon.
zymurgy42
Re: Webcamera Plugin
Postby cncdrive » Mon Feb 27, 2017 2:42 am
Function: int Showplugin(string pluginfilename)
Description: This function calls the Showup event of a UCCNC plugin installed in the /Plugins directory. The parameter is a string which is the name of the plugin file including the .dll extension.
The possible return values are the following:
0: The plugin started without problems.
1: The plugin is not enabled and can't run.
2: The plugin was not found, there is no plugin installed with this filename.
3.: The plugin does not have the Showup event implemented.
Example: int returnval = exec.Showplugin("Diagnostics.dll");
Postby cnv » Sun Jun 04, 2017 11:16 am
Is there a way to reposition (offset) the crosshair in this plugin?
(Maybe to be developed later?)
cnv
Postby cnv » Sun Jun 04, 2017 12:09 pm
(Maybe a feature to be developed later?)
cnv
Postby dezsoe » Sun Jun 04, 2017 7:35 pm
cnv wrote:Hi,
I sent a PM on the "yellow" forum.
Postby cncdrive » Sun Jun 04, 2017 10:14 pm
Currently there is no way to change the crosshair position or shape etc., but it is planned that we will further develop this plugin with some new functions soon.
We've just planned to discuss the new to be implemented functionalities with my collegues next week.
Postby cnv » Sun Jun 04, 2017 10:54 pm
Thanks for the quick response!
I'm glad to hear this feature may be on the table for future development.
cnv
Users browsing this forum: Google [Bot] and 4 guests
