M98 calling a remote SUB.
Re: M98 calling a remote SUB.
Postby dezsoe » Fri Jan 19, 2018 12:07 pm
In version 1.2101 there are two new functions, exec.Getcurrgcodelinetext() and exec.Getgcodelinetext(linenumber). I asked for this function to make a macro to show any message in status window (or MessageBox). The idea was to call e.g. M56 (as MSG) and in that line there should be a remark. This macro will get the current line text and cut the remark text and show it. With this technique you can write e.g. "M1000 (subfunc.tap)" and the macro could load the file in the remark and copy its contents to a list type variable and call exec.Codelist(). The only problem is, that the function has some problem, I have to consult with Balázs to correct it. So, I think, in the near future you can use it.
Postby dezsoe » Fri Jan 19, 2018 4:03 pm
