Would like to put in a Feature Request for the ability to adjust the direction the MPG Step/Speed goes on the pendant when the MPG Step/Speed button is pressed to change step size. Right now it changes from 0.001 -> 0.01 -> 0.1 -> 1.0 each time it's pressed. On most things that makes sense but it's is the opposite of what it gets used for. It's not driving a car or audio volume... I don't want to slowly increase step size. I want to dial in locations and smaller steps are required as I get closer to the part. Pressing it 3 times rapidly introduces a risk of a 4th press which can almost guarantee a crash by moving way too far on the next MPG click.
Please feel free to jump in and tell me it's foolish and why. Here's my thought process on the matter. Assuming each part setup cycles between these 4 it results in a unnecessarily large number of button presses. Assuming you started off at 0.001:
From 0.001 change to 1.0 (press 1 times, that's quite the jump for a single button press!)
From 1.0 to 0.1 (press 3 times)
From 0.1 move down to 0.01 (press 3 times)
From 0.01 to 0.001 (press 3 times)
That's 10 button presses for a single axis to change between 4 options, or 30 on a typical 3 axis. I'd like to argue should be closer to 12 be decreasing the step size on each button press. Or if long-time users have become accustom to it perhaps just a way to adjust the preferred direction in the settings.
