Alarm activate after 10 min of Idle
Postby Giani » Mon May 23, 2022 2:12 pm
Hi, i have a machine that uses closed loop drives that gets really hot if there is no movement (standstill) for a period of time.
i would like to activate a output or reset after 10 minute of idle.
Thank you.
Giani
Re: Alarm activate after 10 min of Idle
Postby Battwell » Tue May 24, 2022 12:27 pm
dont your stepper drives have a half current mode setting?
Postby cncdrive » Wed May 25, 2022 7:58 pm
You can program that yourself in a macroloop.
Just check the idle LED and zero a counter if the led is not active and increase the counter otherwise.
If the counter reacher a value then set or reset an output etc.
Postby Giani » Thu May 26, 2022 5:36 pm
i've tried this program:
if(exec.IsMoving())
exec.Wait(2000);
if (exec.IsMoving())
exec.Setoutpin(1, 5);
if (!exec.IsMoving())
exec.Clroutpin(1, 5);
But exec.Wait(2000) won't reset i have to wait (move axis) until the "wait" counts entire time.
I'm used with blocks (alarms) that uses set and reset .
do you know how i reset it or colud you write a counter for uc , variant i know won't work.
Thank you.
Giani
