Hi out there.
I have an older router from a German company EAS Gmbh, and a NC100 controller and EAS(Y) V3 software from the same company. I bought a computer (64 bits) and my routers hardware are not able to run on 64 bits systems. (no driver present for the USB to parallel buffer)
So - using UCCNC and UC300ETH on my mill, i would like to use this software and controller on the old router too, just using another profile.
I created the new UCCNC profile, and I am able to use port #3 on the UC300 ETH to control the old router and it works - BUT i need to be able to control the ENABLE signal parallel to the step signal (do to the function of old stepperdriver-box from the router). The ENABLE signal must not be active before movement is needed otherwise the steppermotors gets warm and there is a noise coming from the motors too.
So my question is:
Is it possible to control the ENABLE signal with a macro that runs in the background like this -
- When steps on pin 2 port 3 is active, then set enable signal high on pin 4 port 3 (x axis)
- when steps on pin 5 port 3 is active, then set enable signal high on pin 4 port 3 (y axis)
- when steps on pin 8 port 3 is active, then set enable signal high on pin 7 port 3 (z axis)
If there is another way to do the same in setting up UCCNC, i would like very much to hear about that.
Can anyone help??
Thanks in advance
Best regards and a Happy New Year /Carsten, Denmark
