Limit switch is reset selectable
PostPosted: Sun Jan 24, 2021 12:32 pm
by esensoy
Its better if I can choose software resets or not when an axis reach to it limit switch,
For me, just stop without resetting is more usefull,
Re: Limit switch is reset selectable
PostPosted: Mon Jan 25, 2021 6:29 pm
by Soler
Why not using the limits as homing switches and then software limits? You can still add limits incase of a serious issue. Why do you need it to stop instead of reset?
PostPosted: Mon Jan 25, 2021 6:44 pm
by esensoy
Because z axis has 400mm stroke and there is a big gear between motor and screw,
Z axis max speed is very low, so my customer do not want to use homing feature,
Beacuse it takes too much time,
