I'm using some macros to control some screen elements. When I click the buttons, there's a delay, and it takes about 1 second before I can press it again. Hotkeys assigned to the buttons do the same thing.
This makes the screen response feel a bit sluggish.
For example, on the jog screen, I have a + and - button that changes the jog percent or step increment, depending on which is active. I basically use the same code in a Mach3 screen, and the macro executes as fast as I can press the keys. But in UCCNC, I can only press the key about 1 time/second. So, If I want to cycle through 5 steps, it takes nearly 5 seconds, where in Mach3 I could do it in about 1 second, with 5 quick taps on the keys.
My custom checkboxes (Toggle buttons that activate hidden checkboxes) also act similarly, taking nearly a second to change state.
Is this because the macros are compiled as needed?
