seperate m3 for laser
Postby Battwell » Fri Nov 01, 2019 10:27 pm
putting a laser on a router as an add on- to both be able to be used in the same profile is pretty awkward at the moment.
using m3 which is trying to switch both spindle and laser on at the same time.
and should analog still be coupled to pwm when laser engrave plugin is in use?
for laser a seperate m3 output would be desirable. and ignore spindle on delay.
