CycleStart and CycleStop OPTIONS
Re: CycleStart and CycleStop OPTIONS
Postby ack1 » Sun Sep 30, 2018 7:40 pm
yes +1!
Raising the Z when feed hold activates is something like, also beeing able to jog while feed hold is active as i can with my current multicam machine. Allows me to remove whatever moved or came loose before resuming.
ack1
Postby cncdrive » Sun Sep 30, 2018 9:38 pm
You can simply do a stop instead of feedhold since stop in the UCCNC is also a controlled motion (with decceleration) and then you can jog.
Rise the Z when stopped can be done using the 3D printer plugin, it is exactly doing that...
Postby ack1 » Mon Oct 01, 2018 8:04 am
that sounds absolutly amazing.
ack1
Postby Regulator » Tue Oct 02, 2018 12:22 am
+1
Regulator
Postby Robertspark » Wed Oct 03, 2018 11:31 am
Terry,
you got me thinking:
viewtopic.php?f=11&t=1544
Postby Battwell » Wed Nov 14, 2018 11:19 am
feedhold as it is works well on a router, leaves spindle running (unlike stop)
great when a cut part spits out from the job and just needs to be moved before continuing.
i prefered how it worked in mach 3 where in feedhold you could say adjust a dro a bit then continue, but uccnc isnt mach3 and ive learnt its work arounds.
obviously, mill and plasma needs differ in what we think feedhold should do.
Postby Dan911 » Thu Nov 15, 2018 1:22 am
Battwell wrote:feedhold as it is works well on a router, leaves spindle running (unlike stop)
Hi Battwell, I agree. I prefer to stop, spindle off, safe Z. Move Axis wherever, do whatever, and when ready press cycle start and continue with Gcode. Fortunately UCCNC has workarounds, plugins and macro's to accommodate everyone's different preference.
Interested in reading your workarounds if you don't mind sharing.
Postby Battwell » Fri Nov 16, 2018 12:50 pm
nothing special dan. feedhold is feedhold only.
if a dro needs a tweek etc stop must be pressed, tweek the dro , restart spindle, press cycle start :-)
** **remember to restart spindle **** !!!!
Postby Dan911 » Sun Nov 18, 2018 1:10 pm
Battwell wrote:nothing special dan. feedhold is feedhold only.
Hi Battwell,
From my testing I see any axis dro movement after Stop() UCCNC will continue with gcode after CYcle Start press as not moved, buffer is cleared, It will not return back to position.
I been working on a plugin that will do this, button press will Stop() shut off spindle and record position. move axis where you like and when cycle start is pressed it will return back to stopped position and continue with settings it was stopped in.
Unfortunately this only works with UCCNC test versions since it uses functions that aren't available for Net2 versions.
viewtopic.php?f=14&t=1552&start=10
