Automatic axis alignment
Postby Demusman » Thu Jun 28, 2018 9:34 pm
Any chance of adding this?
Similar to how 3d printers "auto level" the Z axis.
The feature starts at 1 minute.
https://youtu.be/bhZdbgM6S70
Demusman
Re: Automatic axis alignment
Postby cncdrive » Thu Jun 28, 2018 10:05 pm
You can write a macro like that. It is simple probing and you can rotate the axes via a setpoint with programmed angle using the G68 code.
Postby Robertspark » Thu Jun 28, 2018 10:13 pm
There is also the autoleveller plugin too already
Postby cncdrive » Thu Jun 28, 2018 10:16 pm
Yes, the autoleveler function is also nice, but it is a bit different than what is on the video.
The autoleveler adjusts the XY plane with multiple probing, so the surface can be irregular.
The feature asked for is a simple G68 rotation based on the probed values.
I know you know it Rob, I'm just explaining to Demusman. :)
