"offline mode" should not change machine coordinates
Re: "offline mode" should not change machine coordinates
Postby Vmax549 » Mon Jan 01, 2024 11:36 pm
Once you cam a file to be point of origin at say lower left then that is the only way you can cut that file. Unless you use the program extents to set say upper right to the extents values. But the point of origin will still be lower left.
Just a thought, (;-) TP
Vmax549
Postby cncdrive » Tue Jan 02, 2024 8:20 am
We could add an option to make the controller register the machine coordinates when you turn the offline mode on and write the coordinates back when you turn the offline mode off.
Would this feature help you?
Postby JeCaWo » Tue Jan 02, 2024 7:11 pm
That would definitely help me. And I hope others too. I believe that approach would address every risk I can see with the offline mode.
JeCaWo
Postby CFSAB » Wed Jan 10, 2024 9:54 am
Hi
JeCaWo, I think you and me try to achieve the same thing, or facing the same problem to locate toolpath over some scrap materials.
Take a look at this idea, maybe something that you would like?
viewtopic.php?f=13&t=4698
Best Regards
Mikael
CFSAB
