Open file at startup
Re: Open file at startup
Postby cahit » Sat Feb 27, 2021 4:22 am
hi dezsoe,
i have this code:
Public Sub Loop_event()
If LoopStop Then
Return
End If
LoopWorking = True
reloadcode()
If FirstRun Then
testcmdline()
' Write code here which has to be run on first cycle only...
End If
Try
Catch ex As Exception
End Try
LoopWorking = False
' Console.WriteLine("" + Convert.ToInt32("A"))
End Sub
Dim cnt As Integer = 25
Private Sub testcmdline()
If Not UC.GetLED(25) Then Return
If cnt > 0 Then
cnt -= 1
Return
End If
UC.Loadfile("file to be loaded")
FirstRun = False
End Sub
Dim cnt2 As Integer = 250
Private Sub reloadcode()
If cnt2 > 0 Then
cnt2 -= 1
Return
End If
UC.Callbutton(555) 'reload the same file again
End Sub
after 10 sec he has to reload a file but UCCNC crashes. what i am doing wrong?
cahit
Postby cncdrive » Sat Feb 27, 2021 5:56 am
Make sure to do the file load/reload on the UIthread.
Try to invoike the main UIthread of your form and do the file load/reload there.
Postby eabrust » Sat Feb 27, 2021 4:23 pm
Hi Cahit,
Maybe instead of having your code for loading / reloading the gcode file in the startup/loop event of the main plugin class, take your load / reload code into the form.
You could put the code for loading into the forms into the 'load' or 'shown' event ('shown' event probably gets you enough delay for UCCNC to be active), and just put your 'reload' code into a button that the user presses (unless you need it to be automatic after a certain amount of time from the loading). You'd have to shuffle the 'testcmdline' code to the form class.
If you find it still fires to fast, you could add a threadsleep in there too
Private Sub PluginForm_Shown(sender As Object, e As EventArgs) Handles MyBase.Shown
'thread.sleep(1000)   ' wait for second if form opens faster than UCCNC gets ready.
testcmdline()
 End Sub
Just suggesting for how I tackle the many issues I solve by trial and error (and error and error... :) ) I'm an amateur programmer, so take my suggestions as such .
Users browsing this forum: El Ventu and 3 guests
