G94 is what all the code you've been running has been using. You're always either using G94, or G93.
G94 = Use standard feedrates
G93 = Use Inverse time mode
G90 has nothing to do with them.
MRob wrote:Interesting, unfortunately my gcode is outputting as G1 moves, no G94's in there. Also the files are 10+mb each, and I am regularly changing them around. Maybe I could find a way to use this as a workaround, but would really like to get the post outputting properly! Thanks for linking though, I do appreciate your taking the time to try and help me out. It might just be easier for me to downgrade to mach3 though, unless I can find a way to get proper G93 moves coded in. Have posted to the autodesk post processors forum, maybe someone there will be able to help me.
