Macros - G68 Rotation
Postby Robertspark » Sat Jul 01, 2017 5:06 pm
With regards to G68 - Rotation
Once set, is there any way to find out what the rotation setting is (point of rotation and angle)?
I ask this because if for example I am running a macro which has a different G68 setting, I'd like to be able to establish if G68 is set
If it is set, I'd like to be able to store the current settings
then clear and reset the G68 rotation angle to the macro setting
carry out the macro operation
reset to the original G68 rotation (if it was set).
Re: Macros - G68 Rotation
Postby dezsoe » Sat Jul 01, 2017 11:39 pm
Yes, you can find it in the Activemodal (877) field. It's tricky to extract the values, but not impossible:
string Activemodal = AS3.Getfield(877);                                         // Field 877: Activemodal
string Params = "";
string temp = "";
string[] WordSeparator = new string[] {"|"};
string[] ParamSeparator = new string[] {","};
string[] Modals = Activemodal.Split(WordSeparator, StringSplitOptions.None);
string[] G68Params;
foreach (string s in Modals)
  if (s.Substring(0, 3) == "G68")
    Params = s;
if (Params == "")
  temp = "G69 (not rotated)";
else
  Params = Params.Substring(4, Params.Length - 5);
  G68Params = Params.Split(ParamSeparator, StringSplitOptions.None);
  temp = "G68 A" + G68Params[0] + " B" + G68Params[1] + " " + G68Params[2];
MessageBox.Show(temp);
As you see, first you need to split the modals to get strings including "G69" or "G68[aa.a,bb.b,Rrr.r]". If there is a string with "G68" in the first 3 letters, then you have to cut the beginning and the end of this string and split again. The first two parameters (A and B) are only numbers, the third has the letter "R" also in it.
Postby cncdrive » Sat Jul 01, 2017 11:58 pm
The only issue with this code is that the values there are truncated to 1 digit only, so it is not very precise.
I will make a GetRotate function in the next release so you could get the precise values.
And for temporarily you may read these variables of the exec object:
public double rotX;
public double rotY;
public double rotAngle;
But please use these only as a temporary solution.
Postby Robertspark » Sun Jul 02, 2017 12:03 am
dezsoe, thank you so much for your hard work, I was not expecting that, it is very much appreciated.
Balazs, thanks very much, very much appreciated.
