Material thickness in macro
Postby AUKURAS » Sat Feb 17, 2024 6:18 pm
Hello everyone,
I'm writing a macro for the automatic dust shoe.
What would be the function to get material thickness from the g-code loaded?
Cheers
AUKURAS
Re: Material thickness in macro
Postby ger21 » Sat Feb 17, 2024 6:57 pm
Most g-code does not specify the material thickness. And afaik, there is no g-code for material thickness.
I use an industrial machine that has an automatic dust shoe. It uses a proprietary g-code, and a proprietary controller. The g-code specifies the shoe position at the start of the cut.
One way to do it would be to assign the shoe to the B or C axis, and have your post processor output the shoe position.
Postby AUKURAS » Sat Feb 17, 2024 7:34 pm
Dust shoe already has A axis assigned. My post processor in the beginning of the g-code specifies material dimensions:
Material Size
X:300 Y:300 Z:20
I thought that's universal and there is already a function for it.
I guess I have to do it on the processor side as you have said.
Thanks!
AUKURAS
