Is there anyone on here that does upwork style work for creating or modifying macros for UCCNC.
I have a need to modify a existing ATC macro to add a rotary into it and also to modify a macro for my ATC turrent on my lathe that currently uses Mach3 but want to transition to UCCNC when the lathe update is finally released.
there seems to be a big hole in using uccnc in that if you are not a c++ programmer it is very hard to get uccnc to do what you want it to - I am sure there are lots of other users that have the same issues. I see the potential for a good programmer to make some pocket money and support the community at the same time.
Please send me a dm if you think you could help or reply here so other users could also use your services.
