I tried adding the line to my M6 and then adding a macroloop, but it doesn't work.
Here is my M6...
- Code: Select all
//Example linear toolchanger code
//Tool positions definition
int Chuckopenport = 1;
int Chuckopenpin = 14;
double[] ToolX = new double[11];
double[] ToolY = new double[11];
ToolX[0] = 0; // Tool0 X position
ToolY[0] = 0; // Tool0 Y position
ToolX[1] = 1447.14; // Tool1 X position
ToolY[1] = 192; // Tool1 Y position
ToolX[2] = 1447.14; // Tool2 X position
ToolY[2] = 342; // Tool2 Y position
ToolX[3] = 1447.14; // Tool3 X position
ToolY[3] = 492; // Tool3 Y position
ToolX[4] = 1447.14; // Tool4 X position
ToolY[4] = 642; // Tool4 Y position
ToolX[5] = 1447.14; // Tool5 X position
ToolY[5] = 792; // Tool5 Y position
ToolX[6] = 1447.14; // Tool6 X position
ToolY[6] = 942; // Tool6 Y position
ToolX[7] = 1447.14; // Tool7 X position
ToolY[7] = 1092; // Tool7 Y position
ToolX[8] = 1447.14; // Tool8 X position
ToolY[8] = 1242; // Tool8 Y position
ToolX[9] = 1447.14; // Tool9 X position
ToolY[9] = 1392; // Tool9 Y position
ToolX[10] = 1447.14; // Tool10 X position
ToolY[10] = 1542; // Tool10 Y position
double SafeZ = 145;
double pickupSafeZ = 75;
double Ztoolrelease = -61;
double Ztoolpickup = -61;
int Newtool = exec.Getnewtool();
int Currenttool = exec.Getcurrenttool();
if(Newtool == -1) // If new tool number is -1 means a missing T code, so we need to stop here...
return;
if(Newtool <1 || Newtool >6) // Tool number is out of range, so we need to stop here...
return;
if(Newtool == Currenttool) // Same tool was selected, so do nothing, stop here...
return;
if(!exec.GetLED(56)||!exec.GetLED(57)||!exec.GetLED(58)) // If machine was not homed then it is unsafe to move in machine coordinates, stop here...
MessageBox.Show("The machine was not yet homed, do homing before executing a tool change!");
exec.Stop();
return;
while(exec.IsMoving()){}
// Get current XY machine coordinates to return to this position at the end of the macro
double Xoriginalpos = exec.GetXmachpos();
double Yoriginalpos = exec.GetYmachpos();
// Stop spindle if running and Move Z up
exec.Stopspin();
exec.Code("G49G00 G53 Z"+ SafeZ); // Move Z up safe
if(Currenttool!=0) // No need to drop down tool if current tool number is zero
// Move to old tool position on XY plane
exec.Code("G00 G53 Y" + ToolY[Currenttool]);
exec.Code("G00 G53 X" + ToolX[Currenttool]);
// Drop current tool
exec.Code("G00 G53 Z"+ Ztoolrelease); // Move Z axis down to tool holder position
exec.Setoutpin(Chuckopenport, Chuckopenpin); // Open the chuck with pneumatic valve
exec.Wait(1000); // Wait one 1000msec
exec.Code("G00 G53 Z"+ pickupSafeZ); // Move Z up
exec.Clroutpin(Chuckopenport, Chuckopenpin); // added solenoid close
// Move to new tool position on XY plane
exec.Code("G00 G53 X" + ToolX[Newtool] + " Y" + ToolY[Newtool]);
// Pick new tool
exec.Setoutpin(Chuckopenport, Chuckopenpin); //added solenoid open
exec.Code("G00 G53 Z"+ Ztoolpickup); // Move Z axis down to tool holder position
exec.Clroutpin(Chuckopenport, Chuckopenpin); // Close the chuck with pneumatic valve
exec.Code("G00 G53 Z"+ SafeZ); // Move Z up
// Move back to start point
//exec.Code("G00 G53 X" + Xoriginalpos + " Y" + Yoriginalpos);
// Measure new tool will go here....
exec.Code("G43 H"+Newtool); // Load new tool offset
exec.Wait(200);
if(!exec.Ismacrostopped()) // If tool change was not interrupted with a stop only then validate new tool number
exec.Setcurrenttool(Newtool); //Set the current tool -> the new tool
exec.Writekey("LastTool", "ToolNumber", NewTool.ToString()); // Save tool number
//MessageBox.Show("Tool change done.");
else
exec.StopWithDeccel();
MessageBox.Show("Tool change was interrupted by user!");
This M6 has been butchered together, please point out anything that looks iffy
I also added the macroloop, but rather than set the previous tool it just sets tool 0.
In the error log I get "CS0103 | in line: 129 | error text: The name 'NewTool' does not exist in the current context"
Any help appreciated
