M6 Macro Help
M6 Macro Help
Postby Daywalker » Sun Jul 31, 2022 6:11 pm
Hi Everyone,
Need some help with an M6 macro.
I rewrote a macro, but I had a few problems with ATC monitoring.
ATC Spindle has 2 PNP sensors. Which are connected to X310 & X311 on the UC300ETH & UB1. (Say port 3 / pin 10 & 11).
LED 95 (LED_DRAWBAR) = Drawbar State
LED 96 (LED_TOOL_INSERT) = Tool Insert State
ATC Spindle Initial state empty = LEDs (Both) -> ON
Drawbar Open = LED 95 (LED_DRAWBAR) -> Off
Drawbar Closed = LED 95 (LED_DRAWBAR) -> ON
and
Tool Insert = LED 96 (LED_TOOL_INSERT) -> Off
     // Opens power drawbar to ensure that the new tool can be accepted
         if (Debug) { MessageBox.Show("Debug: Open Drawbar ...(Unclamp)"); }
             exec.Setoutpin(Chuckopenport, Chuckopenpin);          // Opens power drawbar to ensure that the new tool can be accepted
             while(exec.IsMoving()){}
             exec.Wait(UnclampTimer);
             // check Collet has opened
             while(!AS3.GetLED(LED_DRAWBAR))
                if (Debug) { MessageBox.Show("Debug: ATC Drawbar Open!"); }
                Thread.Sleep(1);
                if(exec.Ismacrostopped())
                ErrorCheck = true;
                  exec.Clroutpin(Chuckopenport, Chuckopenpin);
                  exec.Wait(10);
                  exec.StopWithDeccel();
                  exec.Setvar(0, 100);            //stops manual change macroloop blocking the output for eject
                  MessageBox.Show("Tool change was interrupted at collet open!");
                  return;
            // Pick new tool
            if (Debug) { MessageBox.Show("Debug: Pick New Tool"); }
            exec.Code("G00 G53 Z"+ Ztoolpickup); // Move Z axis down to tool holder position
            // Clamp power drawbar to retrieve tool
            if (Debug) { MessageBox.Show("Debug: Close Drawbar...(Clamp)"); }
            exec.Clroutpin(Chuckopenport, Chuckopenpin); // Close the chuck with pneumatic valve
            exec.Wait(ClampTimer); // Wait
            // Check Drawbar is Closed
            while(AS3.GetLED(LED_DRAWBAR))      // check tool has locked
             if (Debug) { MessageBox.Show("Debug: Drawbar Close / Clamp"); }
             exec.Wait(100);
             //Thread.Sleep(1);
               MessageBox.Show("Tool not locked or no tool!");
               return;
            // Move to Pre Position
            if (Debug) { MessageBox.Show("Debug: Z UP to Pre-Position!"); }
            exec.Code("G1 F5000 G53 Z"+ (Ztoolrelease + Zprepos));          // Move Z axis down to tool holder position
            // Check Tool Insert
            while(!AS3.GetLED(LED_TOOL_INSERT))      // check tool has locked
             if (Debug) { MessageBox.Show("Debug: Tool Locked / Insert!"); }
             Thread.Sleep(1);
               return;
            // Move back to Pre Release Y
            if (Debug) MessageBox.Show("Debug: Move Out of Pocket to PreRelease Y...!");
            exec.Code("G00 G53 Y" +  ypre);
Everything works fine until "Check Tool Insert". This keeps running in the loop.
Does anyone know where my mistake is?
Thank you in advance.
Regards from Germany
Udo
(UC300ETH & UB1)
[Yeah, I use a Translator ;-) ]
Daywalker
Re: M6 Macro Help
Postby k7matrix » Sat Oct 01, 2022 9:57 pm
Have you found a solution? I also have a similar problem.
k7matrix
