Page 1 of 2
Macro Wizard / Form >> TextField Limit to a number range?
Posted:
Thu Mar 14, 2019 9:44 pm
by Robertspark
Odd ball question----
I know how to limit a textfield to 2 digits and I know how to limit to numbers only.
But, is there a way to limit the typed range to say 0-12??
Re: Macro Wizard / Form >> TextField Limit to a number range
Posted:
Thu Mar 14, 2019 10:13 pm
by Vmax549
Set up text box validation and then define your parameters.
Just a thought, (;-) TP
Posted:
Thu Mar 14, 2019 10:22 pm
by Robertspark
Well I got this far:
- Code: Select all
void textBox1_KeyPress(object sender, KeyPressEventArgs e)
if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar) )
e.Handled = true;
Posted:
Thu Mar 14, 2019 10:35 pm
by Vmax549
Textbox validation is your friend
private void textBox1_Validating(object sender, CancelEventArgs e)
if (textBox1.Text != "something")
e.Cancel = true;
Posted:
Thu Mar 14, 2019 11:04 pm
by Dan911
Hmmm, don't think you answered his question.
Don't let textbox value > 12. I have a routine but want to see what you come up with first. Don't worry about posting something silly you can just delete.
Posted:
Thu Mar 14, 2019 11:17 pm
by Robertspark
The validating didn't work
I've had a few goes along the lines of:
- Code: Select all
private void textBox1_KeyPress(object sender, KeyPressEventArgs e)
if (!char.IsControl(e.KeyChar) && !char.IsDigit(e.KeyChar))
if (textBox1.Text == "0" || textBox1.Text == "1" || textBox1.Text == "3")
e.Handled = true;
- Code: Select all
int i = Convert.ToInt32(textBox1.Text);
if (i >=0 && i >= 12)
e.Handled = true;
Posted:
Thu Mar 14, 2019 11:23 pm
by Robertspark
I guess I could always use a numeric UP Down control....
Posted:
Thu Mar 14, 2019 11:25 pm
by Robertspark
I'll use the numeric up down it will meet my needs easier for what I want to do
Posted:
Thu Mar 14, 2019 11:31 pm
by Dan911
Hey Rob, possibly only allowing digits and using index of textbox and add should work
textBox.Text.Substring(index, 0) + textBox.Text.Substring(index, 1)
of course do your conversions along the way.
Posted:
Fri Mar 15, 2019 7:31 am
by Dan911
Just wanting to limit value in textbox 0-12 you can just use the textbox MaxLength property for char amount and set to 2 and just check for 11. If allowing a decimal it can get a little more tricky.
- Code: Select all
textbox.MaxKength = 2;
