Macro Wizard Code Snippet >> RadioButton (+Groupbox)
Postby Robertspark » Wed Jan 16, 2019 11:36 pm
One of a group of example components that was going to put together as Macro Wizard Code Snippets
This one is for radiobuttons (and groupboxes).
Basically save it as a macronumber file of your choosing (such as M10002.txt) and run it via the mdi.
5x Radio Buttons will popup on a form, with a "Post G-Code" button.
2 of the radiobuttons are within a Groupbox and 3 are on the form
The groupbox allows you to group the radiobuttons as only one radiobutton can be selected at any one time..... unless you place them in a groupbox..... which allows you to then add them in groups
you can run any code and it will post the gcode to the Codeview window.
// ##  RadioButton Wizard Example, M10002
//Set up the form for Wizard
MyForm = new Form();
MyForm.Size = new System.Drawing.Size(1200, 750);
MyForm.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen;
MyForm.Text = " UCCNC xxxxx Wizard vx.xxxxx ";
//((System.ComponentModel.ISupportInitialize)(this.numericUpDown1)).EndInit();
//Define the objects on the form
            // radioButton1
            radioButton1.AutoSize = true;
            radioButton1.Checked = true;
            radioButton1.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            radioButton1.Location = new System.Drawing.Point(24, 36);
            radioButton1.Name = "radioButton1";
            radioButton1.Size = new System.Drawing.Size(101, 24);
            radioButton1.TabIndex = 0;
            radioButton1.TabStop = true;
            radioButton1.Text = "radioButton1";
            radioButton1.UseVisualStyleBackColor = true;
            // radioButton2
            radioButton2.AutoSize = true;
            radioButton2.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            radioButton2.Location = new System.Drawing.Point(24, 70);
            radioButton2.Name = "radioButton2";
            radioButton2.Size = new System.Drawing.Size(101, 24);
            radioButton2.TabIndex = 1;
            radioButton2.Text = "radioButton2";
            radioButton2.UseVisualStyleBackColor = true;
            // groupBox1
            groupBox1.Controls.Add(this.radioButton1);
            groupBox1.Controls.Add(this.radioButton2);
            groupBox1.Font = new System.Drawing.Font("Arial Narrow", 14.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            groupBox1.Location = new System.Drawing.Point(25, 48);
            groupBox1.Name = "groupBox1";
            groupBox1.Size = new System.Drawing.Size(223, 118);
            groupBox1.TabIndex = 2;
            groupBox1.TabStop = false;
            groupBox1.Text = "groupBox1";
            // radioButton3
            radioButton3.AutoSize = true;
            radioButton3.Checked = true;
            radioButton3.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            radioButton3.Location = new System.Drawing.Point(302, 63);
            radioButton3.Name = "radioButton3";
            radioButton3.Size = new System.Drawing.Size(101, 24);
            radioButton3.TabIndex = 3;
            radioButton3.TabStop = true;
            radioButton3.Text = "radioButton3";
            radioButton3.UseVisualStyleBackColor = true;
            // radioButton4
            radioButton4.AutoSize = true;
            radioButton4.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            radioButton4.Location = new System.Drawing.Point(302, 98);
            radioButton4.Name = "radioButton4";
            radioButton4.Size = new System.Drawing.Size(101, 24);
            radioButton4.TabIndex = 4;
            radioButton4.Text = "radioButton4";
            radioButton4.UseVisualStyleBackColor = true;
            // radioButton5
            radioButton5.AutoSize = true;
            radioButton5.Font = new System.Drawing.Font("Arial Narrow", 12F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            radioButton5.Location = new System.Drawing.Point(302, 132);
            radioButton5.Name = "radioButton5";
            radioButton5.Size = new System.Drawing.Size(101, 24);
            radioButton5.TabIndex = 5;
            radioButton5.Text = "radioButton5";
            radioButton5.UseVisualStyleBackColor = true;
      // postGcode - BUTTON
      postGcode.Location = new System.Drawing.Point(222, 653);
           postGcode.Name = "postGcode";
           postGcode.Size = new System.Drawing.Size(302, 37);
           postGcode.TabIndex = 20;
           postGcode.Text = "Post Gcode";
           postGcode.UseVisualStyleBackColor = true;
           postGcode.Click += new EventHandler(postGcode_Click);
// Define the Event Handler  (VERY IMPORTANT)
           // Wizard Form
       MyForm.Controls.Add(postGcode);
       MyForm.Controls.Add(radioButton5); // Radio Button 5
            MyForm.Controls.Add(radioButton4); // Radio Button 4
            MyForm.Controls.Add(radioButton3); // Radio Button 3
            MyForm.Controls.Add(groupBox1); // Group Box 1
MyForm.ShowDialog();
      //*************** Starting of the Events Section *****************************
#Events
Form MyForm; //This is a global variable, a Windows Form
// DEFINE all of the elements of the Form HERE (VERY IMPORTANT)
   RadioButton radioButton1 = new RadioButton();
        RadioButton radioButton2 = new RadioButton();
        GroupBox groupBox1 = new GroupBox();
        RadioButton radioButton3 = new RadioButton();
        RadioButton radioButton4 = new RadioButton();
        RadioButton radioButton5 = new RadioButton();
      Button postGcode= new Button();
// ADD EVENTS BELOW HERE:
 void postGcode_Click(object sender, EventArgs e)
      string Gcode = "";
 // STARTUP / LINITIALISATION SECTION
      Gcode = (Gcode +  " ( TEST CODE ) " ) + Environment.NewLine;
      Gcode = (Gcode +  "  " ) + Environment.NewLine;
 // BODY  SECTION
      Gcode = (Gcode +  " ( radioButton1 " + radioButton1.Checked  + " ) ") + Environment.NewLine;
      Gcode = (Gcode +  " ( radioButton2 " + radioButton2.Checked  + " ) ") + Environment.NewLine;
      Gcode = (Gcode +  " ( radioButton3 " + radioButton3.Checked  + " ) ") + Environment.NewLine;
      Gcode = (Gcode +  " ( radioButton4 " + radioButton4.Checked  + " ) ") + Environment.NewLine;
      Gcode = (Gcode +  " ( radioButton5 " + radioButton5.Checked  + " ) ") + Environment.NewLine;
 //FINISHING SECTION
       Gcode = (Gcode +  ("M30")) + Environment.NewLine;
       System.IO.File.WriteAllText(Application.StartupPath + @"/Example_codes/Test.tap" , Gcode );
     // Load and Run File
       exec.Loadfile(Application.StartupPath + @"/Example_codes/Test.tap");
    exec.Callbutton(402);
// Close the Wizard
MyForm.Close();
Happy coding :geek:
