Would some kind person write me a simple macro?
Postby Greolt » Thu Sep 14, 2017 2:50 am
This is very basic and I should be able to do it easily.
However I find the best way for me to get started with the concept is to look at an existing macro and see how it is done.
The task is to control my router spindle (VFD) via modbus
The modbus master is set up and communicating with my Hitachi X200 VFD
I can do all of the needed control manually via the modbus master. By manually entering values in the "Variables Table" while the loop is running.
My assumption is that it now needs a macroloop to manipulate those variables when certain actions take place.
The macro needs to do the following.
1. When LED 50 goes active, write a "1" in register zero of the variables table. LED 50 is "SpindleCW"
2. When LED 50 goes inactive, write a zero in register zero of the variables table.
3. Read DRO 2451, divide the value by 6, and then write it in register one of the variables table. This is the speed setting for VFD
4. Read register 2 in the variables table , divide it by 125 and write the value to DRO ??? (DRO number not decided yet. will be a user assigned DRO)
Thanks in advance for any help.
Greolt
Re: Would some kind person write me a simple macro?
Postby Greolt » Thu Sep 14, 2017 4:02 am
Felt that I had to at least make an attempt.
Most likely it is all wrong and syntax all over the place.
//check LED 50 , if it is active then set modbus register zero to one, else set it to zero
bool Spin = AS3.GetLED(50);
if Spin>0{
exec.SetModbusregister(0, 1)}
else{
exec.SetModbusregister(0, 0)}
// read field 2541, divide value by 6, write value to modbus register 1
// the value written to the modbus register should be in the range 0 - 4000
string Speed = AS3.Getfield(2451);
Speed = Speed/6;
exec.SetModbusregister(1, Speed);
// read modbus register 2, divide value by 125, write value to DRO 3000
// the value read from modbus register will be in the range 0 - 2000
string Amps;
exec.GetModbusregister(2, out Amps);
Amps = Amps/125;
AS3.Setfield(Amps, 3000);
Greolt
Postby dezsoe » Thu Sep 14, 2017 9:36 am
Here is your macro with some corrections:
if (Spin)
  exec.SetModbusregister(0, 1);
else
  exec.SetModbusregister(0, 0);
double Speed = AS3.Getfielddouble(2451);
Speed = Speed/6;
exec.SetModbusregister(1, (ushort)Convert.ToInt32(Speed));
ushort Amps;
if (exec.GetModbusregister(2, out Amps))
  AS3.Setfield(Amps / 125, 3000);
Postby Greolt » Thu Sep 14, 2017 10:16 am
Thanks very much dezsoe.
I will try it out.
Greolt
Postby A_Camera » Thu Sep 14, 2017 1:18 pm
I did not write a macro for you according to your specifications, but I share what fits my VFD. This is a stripped down version of what I actually use, but it should be pretty easy for you to work with. The parts which I removed handle some VFD parameters, like spindle speed reached and some other monitoring functions. The basic principle is simple, check CW and CCW LEDs and send the matching command to the VFD, as well as the frequency matching the desired spindle RPM, compensated for the SS override and checked for maximum RPM. I allow any RPM between zero to maximum RPM.
//    M20305 Seting the spindle speed, runing CW/CCW and reading some VFD and spindle parameters.
//   This is a Modbus interface macro and is running in a macro loop.
// When this macro is called it will check the Set Spindle Speed and the Speindle Speed Override DRO
// and will calculate the matching frequency. This is set in Modbus register which is sent to the VFD.
// After this step it will check the state of RUN CW/CCW LEDs and will set the necessary VFD commands.
//   Constants
ushort RunSpindleCW       = 129;       // Rexroth EFC5610 RUN CW command
ushort RunSpindleCCW       = 133;       // Rexroth EFC5610 RUN CCW command
ushort StopSpindleRun       = 136;      // Rexroth EFC5610 STOP command
ushort SSetDRO          = 869;
ushort SactDRO          = 870;
ushort SSOverriddenDRO      = 2451;
ushort MaxSpindleSpeedDRO   = 178;
double MaximumRPM       = 24000;
ushort SpindleRunReg      = 0;      // Displayed UCCNC Modbus register list
ushort VFDFrequencyReg       = 1;
//   Variables
string SspeedOverride;
int IndexOfPercentSign;
string SSpeedOverride;
double SSpeedHz;
//   Program starts here
//-------------- Set spindle speed value firtst ---------------------------------------------------------------
   MaximumRPM = AS3.Getfielddouble(MaxSpindleSpeedDRO);
   SSpeedHz = ( AS3.Getfielddouble(SSOverriddenDRO));
   if (SSpeedHz > MaximumRPM)
      SSpeedHz = MaximumRPM;   // Force maximum RPM to prevent exception
// Calculate the matching RPM frequency and send the value to Modbus register.
   exec.SetModbusregister(VFDFrequencyReg, (ushort) Convert.ToUInt16(SSpeedHz / 0.6));
//-------------- Send start/stop command for the spindle --------------------------------------------------------
//   Check the CW and CCW LEDs and convert the state to spindle control commands.
//   The command is set in the Modbus register which is sent to VFD using the UCCNC Modbus internal handler.
//   Check CW and CCW LEDs, start or stop the spindle based on LED states.
//   After exiting this macro the Modbus register is set up for CW, CCW or Stop
   if ( AS3.GetLED(50) == true )  // If the RUN CW LED is active
        exec.SetModbusregister(SpindleRunReg, RunSpindleCW);   //Turn spindle on in CW rotation if LED is on
   else
   if ( AS3.GetLED(51) == true )  // If the RUN CCW LED is active
          exec.SetModbusregister(SpindleRunReg, RunSpindleCCW);   //Turn spindle on in CCW rotation if LED is on
   else // CW and CCW LEDs are off, send turn spindle OFF commnad
          exec.SetModbusregister(SpindleRunReg, StopSpindleRun);    // Send Rexroth EFC5610 STOP command to VFD
//   End of program
Of course, Modbus master plugin must be enabled, configured and run as well.
Postby Greolt » Thu Sep 14, 2017 9:25 pm
I have your corrected macro running. Thanks again.
A_camera
Thanks for your example. I will spend some time altering it to my needs. It will help me learn a little.
On my Milling Machine I occasionally use spindle reverse but this is for a router and I never use reverse.
What number range is recommended for user DROs and user macros?
Thanks very much both for taking the time.
Greolt
Postby ger21 » Thu Sep 14, 2017 9:34 pm
Macros need to be between 20000 and 20999.
I use the same range for everything.
Postby Greolt » Thu Sep 14, 2017 11:23 pm
Thanks ger21
Why so high numbers?
"Everything"......does that mean DROs, Labels, Macros, Textfields, etc.
Greolt
Postby cncdrive » Thu Sep 14, 2017 11:31 pm
You can use any positive numbers, except the built in functions, like M10, M11 etc.
The range 20000 to 21999 is the range for macro call button codes. Those numbers can be used to call macros with button presses.
When you use that range and place the same buttonnumber button on the screen then pressing that button will call the same number of macro, but it has to be in the mentioned range.
Postby Greolt » Thu Sep 14, 2017 11:41 pm
OK got that
Greolt
