Notepad++ UCCNC Macro Style + Autocomplete Addin
Postby Robertspark » Mon Sep 26, 2016 6:35 pm
As per the title.....
Within the zip file is a PDF explaining what to do (+ with pictures ... :roll: )
There is the UCCNC.XML file which you need to copy and paste into the: C:\Program Files (x86)\Notepad++\plugins\APIs folder.
Then there is the UCCNC Style.XML file which you will need import via the Languages + User Defined Languages.
Also I'd recommend that you change the Settings >> Style Configurator to Deep Black Theme or change the Styles
256kB file limit! ... googledrive link below:
https://drive.google.com/open?id=0B9eqGqWQVBbWZHJKbFZZNDl6OEE
Re: Notepad++ UCCNC Macro Style + Autocomplete Addin
Postby Robertspark » Mon Sep 26, 2016 11:16 pm
... well I did burn the midnight oil on it, but once I got going at understanding notepad++ I kind of thought I better finish .... another string to the bow and something learnt....
(must admit I have updated the style.XML this evening.... if you have downloaded it before about 9pm (~3 hrs ago... I'd download it again, delete the user defined language and add in the new Language style as there were a few things that were not working right......)
TP, thanks very much for the tip on using the error log file...... the question is the line numbers don't correspond to the macro, is that because it ignores whitespace?
Postby 1JUMPER10 » Fri Dec 08, 2017 9:05 pm
Hi Robert -
Very nicely done. The pics were very helpful.
1JUMPER10
Postby Robertspark » Fri Dec 08, 2017 10:40 pm
No problem,
One thing that I've done since is added in a few of the other standard functions that I use a lot + have been added items such as #Events
Screenshot attached
And some of the math + convert functions that i use
https://msdn.microsoft.com/en-us/librar ... s(v=vs.110).aspx
note there are a few newer methods (functions) that have been added to uccnc since I did that originally... hence go through the index on my uccnc macro manual and check you have everything listed.
I'll have a go at updating it sometime (didn't think anyone was using it)
2017-12-08 22_35_57-_C__UCCNC_Profiles_Macro_Default_M70.txt - Notepad++.png
Postby ger21 » Fri Dec 08, 2017 11:59 pm
I use it all the time, but I've made a lot of changes myself.
Thanks for the work you did on this.
