Wizard Plugin
Re: Wizard Plugin
Postby Vmax549 » Tue May 29, 2018 4:03 pm
Hi Dan , It is working ok now V6.
(;-) TP
Vmax549
Re: Wizard Plugin
Postby Dan911 » Wed May 30, 2018 12:49 am
Vmax549 wrote:Hi Dan , It is working ok now V6.
(;-) TP
Thanks for the update!
Your comments, guidance, help is always appreciated.
Re: Wizard Plugin
Postby Robertspark » Sat Jun 16, 2018 12:22 pm
Dan, nice plugin, i'd really like to do a simple one for plasma {no Z / depth of cut}
Rob
UC400eth, UC300eth, UCCNC v1.2105, Neuron Lite
UCCNC v1.2105 Macro Manual
Re: Wizard Plugin
Postby epracefan@gmail.com » Tue Jul 03, 2018 3:18 pm
Hi Dan and thanks for creating this.
Thought I'd give Wizard V6 a spin and have a problem. I hit Start to clear the temp file and created a 2" pocket .25" deep in 2 passes at X6,Y6. The generated Gcode has my Z plunging to -.625" right off the bat. The second pass moves to Z-.75".
What am I doing wrong?
Ed
epracefan@gmail.com
Re: Wizard Plugin
Postby Dan911 » Tue Jul 03, 2018 9:33 pm
epracefan@gmail.com wrote:Hi Dan and thanks for creating this.
Ed
Hi Ed,
You are not doing anything wrong, if you try running code in offline mode or demo mode you will see it runs correctly. I think what you are missing is that after your Z.5 (Z travel setting) move to X6 Y6 there's a
G91(incremental Mode).
Your settings are to pocket .25 in 2 passes(.125 per pass)
.5 + .125 = -0.625
Back to Z travel setting (.5) than back to X6 Y6 for second pass(.125)
.5 + .25 = -.75
( Quick Cam Wizards Version 1.007)
(Date:2018-07-03 Time:05:01:11)
G00G17G90G40G49G80
G0 Z.5
G1X6 Y6 F50
T0 M6 (Tool Diameter .25)
S18000 M3
G91
G1 Z-0.625F15
G1 Y0.125 F50
G2 Y0 I0 J-0.125
G1 Y0.125 F50
G2 Y0 I0 J-0.25
G1 Y0.125 F50
G2 Y0 I0 J-0.375
G1 Y0.125 F50
G2 Y0 I0 J-0.5
G1 Y0.125 F50
G2 Y0 I0 J-0.625
G1 Y0.125 F50
G2 Y0 I0 J-0.75
G1 Y0.125 F50
G2 Y0 I0 J-0.875
G2 Y0I0 J- 0.875
G0 Z0.625
G1Y-0.875
G1 Z-0.75F15
G1 Y0.125 F50
G2 Y0 I0 J-0.125
G1 Y0.125 F50
G2 Y0 I0 J-0.25
G1 Y0.125 F50
G2 Y0 I0 J-0.375
G1 Y0.125 F50
G2 Y0 I0 J-0.5
G1 Y0.125 F50
G2 Y0 I0 J-0.625
G1 Y0.125 F50
G2 Y0 I0 J-0.75
G1 Y0.125 F50
G2 Y0 I0 J-0.875
G2 Y0I0 J- 0.875
G0 Z0.75
G90
Re: Wizard Plugin
Postby Vmax549 » Tue Jul 03, 2018 10:14 pm
Hi Dan, When you make a change to INC mode you may want to make a comment alerting teh user that distance mode has changed. Most users do not understand Inc programing very well. The message will alert them to a change.
G91 ( Switched to INC mode)
G90 ( Switched to ABS mode)
Also just a note but having a starting Z helps users to understand teh code when transitioning from Zrap to teh start of teh feature where ever it may start as it does not always start at Z0.
G0 Z.500 (Zrap)
G0 Z0.000( Zstart)
G91 (Switch to INC mode )
G1 Z-.125 ( 1st step depth)
code
code
code
G1 Z-.125 (2nd step depth total -.250)
Just a thought, (;-) TP
Vmax549
Re: Wizard Plugin
Postby Dan911 » Tue Jul 03, 2018 10:43 pm
Hi Terry,
Commenting on INC and ABS lines can help in causing confusion to some and is something I will definitely consider adding when/if I do and updated version...Thanks
Vmax549 wrote:ALSO there may be an error in your math on teh 2nd loop as it is still in INC mode and teh Z RAISED by a value of .625. Should it not have lowered by a value of -.125 ??
This is no error, the Z raises after first pass (-.125) to the users set Z travel which is .5 in this case, and moves to start position for final pass -.75.
I edited post to add Gcode for all to test.
Re: Wizard Plugin
Postby Vmax549 » Tue Jul 03, 2018 10:55 pm
YEP I did not read it very carefully (;-) I saw my error and edited teh post.
You are doing well with Wizards keep up teh good work.
(;-) TP
Vmax549
Re: Wizard Plugin
Postby Dan911 » Wed Jul 04, 2018 2:36 am
Vmax549 wrote:YEP I did not read it very carefully (;-) I saw my error and edited teh post.
(;-) TP
Thanks Terry! Just having fun learning and taking advantage of the customizing UCCNC provides.
Re: Wizard Plugin
Postby epracefan@gmail.com » Wed Jul 04, 2018 12:29 pm
Dan911 wrote:
Hi Ed,
You're correct, Dan, I completely overlooked the G91. Thanks for pointing that out.
Ed
epracefan@gmail.com
