Coolant on/off on Rapids
Re: Coolant on/off on Rapids
Postby alex_s » Wed Jan 03, 2018 12:11 pm
i thought along something like this
const double ZHeight = 5;
double Zpos = AS3.Getfielddouble(228);
bool stateNow = Zpos < ZHeight &&  AS3.Getbuttonstate(666);
if (lastState != stateNow) {
   lastState = stateNow;
if(stateNow) {
   exec.Miston();
   while(exec.IsMoving()){}
else {
   exec.Stopcoolant();
i made an extra button for MistOn while Cutting, and ZHeight at 5. So the Misting starts before the bit enters the material and still blows when it leaves. 5 is very save 1 or 2 should also work, the valve solenoid operates fairly quick and i generally only rapid to 3mm above the part.
i also used the execs directly so you can set the pin in option as usual, not tested yet because its effing cold right now in the Shop ^^
alex_s
Postby Dan911 » Thu Jan 04, 2018 4:25 pm
Hi Alex,
I'm glad you found my suggestion using a Z height useful. I'm also very happy to see you eliminated the exec.code(G4) for a pause because that wouldn't have worked with Gcode running. Thanks to Dezsoe who pointed this out to me, and I had to promised him I'll add a Breathalyzer test to my keyboard to continue posting.
Since it's only 11am here I think I can safely make some remarks to your posted macro.
Haven't tested your macro but it seems you eliminate the M7 call from gcode. I suggest using the macro loop for button on/off and M7 calls with Z height. If you have your toggle button just set to true/false this should work.
If anyone sees errors or have a better solution please post, I do think many can find this useful.
// Mist on/off  M7 and ZHeight with toggle button override
bool ButOnOff = AS3.Getbuttonstate(20302);
bool stateNow = ((Zpos < ZHeight) &&  (exec.GetLED(52) && (!ButOnOff)));
  if(stateNow) {exec.Setoutpin(Port, Pin);}
  else
  if(ButOnOff) {exec.Setoutpin(Port, Pin);}
else
{exec.Clroutpin(Port, Pin);}
#Events
const int Port = 1;     // Port number
const int Pin = 1;     // Pin number
const double ZHeight = 0; // Set  Z Height below on above off
Postby alex_s » Thu Jan 04, 2018 4:32 pm
Hi Dan,
yep as pointed out by this thread z height seems to make much more sense here.
Thanks for looking into it, the button is a toggle true/false button.
The pause did not seem to be an good option, even if it would work, because the movement could be janky, and if you set zHeightValue above zZero with an equivalent amount for the specific solenoid and travel speeds it should not be needed
I also think that this is very use full for anyone who want's to save on coolant in Mist setup, especially the special expensive stuff. I wanted to use a different Button for it because i sometimes use my mister as semi flood ^^
here is a nice Datron video with a more advanced integration of the cooling feature, only on actual cutting + directional
https://www.youtube.com/watch?v=7PQxwte-2z4
but this solution is more then adequate for at least my purpose
cheers Alex
alex_s
Users browsing this forum: cncdrive and 10 guests
