G96 Constant Surface Speed Macro + Macroloop (attempt!)
Re: G96 Constant Surface Speed Macro + Macroloop (attempt!)
Postby vargai » Sat Jun 09, 2018 12:17 am
Dezsoe,
Without giving "f"- this macro sets SSO to zero.
Sorry but I am 4 year old at C sharp.
How to give the requested surface speed?
István
vargai
Postby Robertspark » Sat Jun 09, 2018 8:46 am
vargai
have a read of the first post:
M751 {Dxxxx, Exxxx} sets your maximum spindle rpm (Dvar) and sets your Spindle Surface Speed in UNITS per min (note this is not feet or meters per min!!!, so if you desire 200 meters / min surface speed, set E200000, sorry I could not come up with a way to know if the machine was in metric or imperial, hence followed the standard that the machine is just set in "units"
There are 3 macros.
two are called macros and one is a macroloop which does the updates of the spindle speed
The only parameters you need to give the macros as Dvar and Evar which are the maximum permitted spindle speed {to avoid overspeeding the spindle} and the Evar which is the desired surface speed.
Deszoe + Vmax have been talking about the macroloop which updates the wrong DRO {its a read only DRO which I did not know}
Rob
UC400eth, UC300eth, UCCNC v1.2106, Neuron Lite
UCCNC v1.2105 Macro Manual
Postby vargai » Sat Jun 09, 2018 10:01 am
vargai wrote:Dezsoe,
István
sorry dezsoe, I did not turn over to page#2 before posting the above
So waiting for the evolution.
István
vargai
Postby vargai » Sat Jun 09, 2018 10:09 am
[quote="Robertspark"]vargai
[quote]M751 {Dxxxx, Exxxx} [quote]
I simply typed M751, after two days recognized my mistake
So with the new information- stimulating SSO I hope all soon will have CSS macro
István
vargai
Postby dezsoe » Sat Jun 09, 2018 9:56 pm
István
As I wrote, it's an experimental code. :) It uses the field 21000 on the screen. You have to make it with the screen editor.
Postby vargai » Sun Jun 10, 2018 8:39 pm
István
Thanks Dezsoe, its working now -at least I can make a macro run ;)
István
vargai
