Huanyang Plug in
Huanyang Plug in
Postby naijin » Fri Apr 05, 2019 1:45 pm
Hi there, what is the current version of the Huanyang plug in and where can I down load it?
Nick
naijin
Re: Huanyang Plug in
Postby ger21 » Fri Apr 05, 2019 2:34 pm
The thread right below this one.
viewtopic.php?f=14&t=432&start=110#p14248
Postby naijin » Sat Apr 06, 2019 9:12 am
Thanks GER21, I thought they were still trials and DAN 911 was still developing it, I was thinking there may be a final version some where.
Nick :oops: :oops:
naijin
Postby Delco » Thu May 23, 2019 10:45 pm
I just downloaded the plugin but dont see any instructions setting the VFD included ? is there a updated txt file somewhere.
Would be nice if the latest version and setup could somehow be pinned to the first post ?
Delco
Postby ger21 » Fri May 24, 2019 1:56 am
HY12 has instructions. Not sure what's changed, though.
Postby Dan911 » Sun May 26, 2019 11:47 pm
Delco wrote:I just downloaded the plugin but dont see any instructions setting the VFD included ? is there a updated txt file somewhere.
There was instructions in post/thread where you downloaded plugin from. This version there's no need to set max freq and max/min rpm, plugin reads it from set settings in vfd. Also added current rpm, current frequency and set frequency, you can view these settings from HY window or create fields with screen edit. Also added send and received data windows to help in trouble shooting,
Some of he textbox's I neglected to add protection from user error input and will eventually post 1 last version and will include set up instructions.
