Get value from NumericUpDown
Re: Get value from NumericUpDown
Postby ger21 » Fri Jan 11, 2019 7:52 pm
What is the error you are seeing?
Postby Jeffsg605 » Fri Jan 11, 2019 8:06 pm
I think you hit the main ones. That would be great.
So I assume there's no way to read in the value from a NumericUpDown yet?
Jeffsg605
Postby Robertspark » Fri Jan 11, 2019 8:30 pm
Jeffsg605 wrote:So I assume there's no way to read in the value from a NumericUpDown yet?
give me a moment.... multitasking
Rob
UCCNC v1.2108 Macro Manual
Postby Robertspark » Fri Jan 11, 2019 8:55 pm
Use one of these below (numericUpDown1.Value is actually a Decimal value)
      double dblnumericUpDown1 = Convert.ToDouble(numericUpDown1.Value);
      string strnumericUpDown1 = Convert.ToString(numericUpDown1.Value);
Rob
Postby dezsoe » Fri Jan 11, 2019 9:25 pm
You should save it in the ValueChanged event, I think.
Postby Robertspark » Fri Jan 11, 2019 9:28 pm
dezsoe wrote:You should save it in the ValueChanged event, I think.
Not necessary, if you are using another event like within a button event..... Depends what your form does.... If you want the value to have instant effect on change then yes
Rob
Postby Jeffsg605 » Sat Jan 12, 2019 2:24 pm
Thank you guys. I'll try both methods. I could have sworn I tried the "Convert.ToDouble(...)" but it didn't work. Maybe I typed it wrong.
In any case, I'll be back at the machine on Monday. I'll let you know, thanks for all the help!
Jeffsg605
Postby cncdrive » Sat Jan 12, 2019 10:20 pm
Things should work, because the UCCNC is using the .NET compiler called (CodeDom), so there is no way that C# functions like Convert.ToDouble is not working, because that would mean that the .NET framework is broken on the computer, but that is also not possible, because then the UCCNC itself would also not work, because it is a .NET application and run by the .Net framework. :)
Postby Jeffsg605 » Sat Jan 12, 2019 10:22 pm
That was my understanding, too. But then how come something like "double x = (double)NumericUpDown1.Value" doesn't work.
Jeffsg605
Postby cncdrive » Sat Jan 12, 2019 10:29 pm
It should work. What is the error message you get?
