variables # "M#3"
variables # "M#3"
Postby Robertspark » Thu Jan 10, 2019 5:35 pm
Just wondering {I've tried it and it doesn't work with UCCNC}
Is it possible to call a variable with say
M#3
M#5
where I could assign any number to #3 and #5 and it would be associated with the M-code
You may ask "why do you want to do this?"
Say I want to plasma cut something, I would assign #3=3 and #5=5 so the gode file would become M3 to fire the torch and M5 to stop the torch.
Say I want to engrave that same code with a plate marker..... I could assign #3=7 and #5=9, now my code would become M7 to turn the engraver on and M9 to turn the engraver off.
Or if I now wanted to use the same code again for lets say a router, I could assign something like #3=300 and #5=500 which becomes M300 and M500 which would include for the Z axis motion
Lets say I was using some "generic" letter gcode such as this which I could scale with G51 X Y and use universally {or that was the thought}
(D LETTER)
G91 G0 X0.1129 Y0.118
M#3
G91 G1 Y1.782 F#505
X0.633
G2 J-0.891 Y-1.782
G1 X-0.633
M#5
G91 G0 X-0.1129 Y-0.118
G91 G0 X2.0000
M99
Is there a reason why M#3 could not be done to share variables?
note: before someone says that if you cut a "D" with that gcode and plasma you'd get dropout {the center will fall out}..... yes I know but you could mark it out with marking mode and a plasma cutter though....
Rob
UC400eth, UC300eth, UCCNC v1.2109, Neuron Lite
UCCNC v1.2108 Macro Manual
Re: variables # "M#3"
Postby Robertspark » Thu Jan 10, 2019 7:41 pm
kind of answered my own question via another solution....
Just call any other macro say M300 for ON and M301 for off and then use a switch statement in there to call the correct code for the various marking / cutting / routing / engraving operations.
Rob
Users browsing this forum: Bing [Bot], laki and 2 guests
