Create and cut or pocket a circle
Postby Dan911 » Fri Dec 28, 2018 7:15 pm
I'm rewriting the wizards in wizard plugin and posting as individuals here. I'm eliminating the use of all the G9I(incremental) calls and adding some request such as a Z start and zero top or bottom of material.
Cut or Pocket a Circle.zip
(20.13 KiB) Downloaded 878 times
Re: Create and cut or pocket a circle
Postby AvB » Wed Jan 16, 2019 11:19 am
I haven't used the UCCNC wizards but wanted to say that for an amateur guy like me, it would be really great for the wizards to have a block of text somewhere on the screen that summarized the basic operations required to use the wizard. I recently used the Mach3 digitize wizard for the first time recently and thought it was crazy that you had to work out the basics through trial and error, when it would have been so much easier if the guy had included some notes like "There is no need to zero the axes before running the wizard. The wizard starts its run from current position. Probing at each point will start from safe height, not start height. Enter probe depth as negative if away is negative on Z axis". Etc,etc.
AvB
Postby Dan911 » Wed Jan 16, 2019 10:42 pm
AvB wrote:I haven't used the UCCNC wizards but wanted to say that for an amateur guy like me, it would be really great for the wizards to have a block of text somewhere on the screen that summarized the basic operations required to use the wizard. I recently used the Mach3 digitize wizard for the first time recently and thought it was crazy that you had to work out the basics through trial and error, when it would have been so much easier if the guy had included some notes like "There is no need to zero the axes before running the wizard. The wizard starts its run from current position. Probing at each point will start from safe height, not start height. Enter probe depth as negative if away is negative on Z axis". Etc,etc.
Postby AvB » Thu Jan 17, 2019 10:57 pm
That's brilliant, thanks.
AvB
Postby ejg3855 » Tue Feb 04, 2020 1:35 pm
I am having some trouble installing this and I am not sure why.
When I go to the "configure plugin" screen and hit show it says "this plugin does not implement the showup event"
Then I tried to make a macro that would call the .dll using the exec.Pluginshowup ("Cut or Pocket a Circle.dll"); and it gives errors.
Any suggestions on what I am missing, I am sure its simple.
ejg3855
Postby Spuds » Tue Feb 04, 2020 5:20 pm
ejg3855 wrote:I am having some trouble installing this and I am not sure why.
When I go to the "configure plugin" screen and hit show it says "this plugin does not implement the showup event".
Same here Dan.
UCCNC 1.2112
Spuds
Postby ger21 » Tue Feb 04, 2020 7:49 pm
I think he needs to recompile the plugin for the newer versions of UCCNC.
Postby dezsoe » Tue Feb 04, 2020 8:54 pm
No, I think it is called by a fixed buttonnumber. If I can recall. :) I hope Dan will come and tell it.
Postby Vmax549 » Sun Jun 07, 2020 8:26 pm
It should use Button # 6333 to start teh Wizard.
IF I remember correctly (;-) TP
Vmax549
Return to UCCNC TOOL BOX
