rotary tool changer- carousel
Postby Battwell » Sat Jul 07, 2018 11:57 am
has anyone already written a full tool change macro for a rotary tool changer?-
im converting an old denford mill at the moment. uses 2 pulses to step between tool numbers. driven by a geared cam.
cant remember what that setup is called. (i know its also used on the new chinese machines)
Uc300eth on router and mill
Re: rotary tool changer- carousel
Postby Vmax549 » Sat Jul 07, 2018 2:57 pm
Are you referring to a Geneva drive system where a full rotation of teh cam make a single step of teh carousel ??
(;-) TP
Vmax549
Postby Battwell » Sat Jul 07, 2018 3:13 pm
That’s the one terry
Takes 2 rotations to move from tool to tool.
Postby Robertspark » Sat Jul 07, 2018 3:32 pm
Impressive (learnt something else today)
https://en.m.wikipedia.org/wiki/Geneva_drive
Rob
UC400eth, UC300eth, UCCNC v1.2105, Neuron Lite
UCCNC v1.2105 Macro Manual
Postby Vmax549 » Sat Jul 07, 2018 10:27 pm
I have done a few different atc version types but so far not a geneva.
I do not see where it would be that hard to do it in UCCNC.
It the drive motor a stepper/servo or a DC motor ?
The hard part would be keeping track of teh Carousel steps verses tool position. But it should not be that hard to do.
I will check and see if I have any old Mach3 routines that would give you a head start on it.
(;-) TP
Vmax549
Postby Battwell » Sun Jul 08, 2018 11:39 am
it has a 220v mains single phase motor, geared to the cam wheel
the index wheel is a circle with a chord chopped off. sensor is on for most of the circle- off when it is along the chord. ( sensor parallel to sides of the index wheel)
i have written a bit of code which has it moving .
trying to work out the best way to record the pulses- the index wheel is a circle with a chord chopped off.
i have it working ok in 1 direction but its not right once reversed.
at the moment i have it running while loops recording both high and low transitions- so confirming movement. .
il post the testing code later for you to suggest improvement.
Postby Battwell » Sun Jul 08, 2018 12:25 pm
So far
Works well - until reversed
https://youtu.be/7ea6354u42E
Postby Battwell » Sun Jul 08, 2018 12:36 pm
int carforwardport=2;
int carforwardpin=17;
int carreverseport=2;
int carreversepin=16;
//exec.Setoutpin (carreverseport,carreversepin);
exec.Wait(100);
exec.Setoutpin (carforwardport,carforwardpin);
for (int i=0; i<12; i++)
//wait for sensor off = movement
while (AS3.GetLED(4));
exec.Wait(10);
if (exec.Ismacrostopped())
exec.Clroutpin (carforwardport,carforwardpin);
exec.StopWithDeccel();
return;
Console.Beep();
exec.AddStatusmessage("off "+ i);
//sensor-off end
//wait for sensor on = next position
exec.Wait(10);
return;
exec.AddStatusmessage("on "+ i);
//exec.Wait(50);
exec.Clroutpin (carreverseport,carreversepin);
exec.Wait(10);
//sensor-on-position found end
return;
Postby Battwell » Sun Jul 08, 2018 1:28 pm
My next head scratcher is orienting the spindle for atc
The spindle is driven by a dc drive which is a bit hit and miss whether it will start rotating at very low speed.
Il need slow rotation to stop it at the sensor position.
I was thinking about using a while loop to ramp up the spindle analogue output in small steps until the sensor position is seen.
Thoughts of a better way?
Postby Vmax549 » Sun Jul 08, 2018 7:47 pm
You need 1 sensor to tell you when teh pin is out of teh slot (Carousel is not moving)
You calculate how many steps to teh next tool position.
oldtool(1) - newtool tool(3) = 2 tool moves * 2 steps per move = 4 signals
if oldtool> newtool then forward
if oldtool< new tool then reverse
Start motor (Direction)
signal = 0
while (signal <= 4)
while (!getsignal)
exec.wait(10);
signal = signal+1
Stop motor (@Tool3)
(;-) TP
Vmax549
