MDI Command Log
Re: MDI Command Log
Postby Vmax549 » Wed Jun 20, 2018 2:08 pm
WOW that was fast.
Thanks Balazs
(;-) TP
Vmax549
Re: MDI Command Log
Postby Vmax549 » Wed Jun 20, 2018 2:13 pm
Hi Dan, Did you use an onclick() or a ontype() function to gather data for teh MDI log ??
Not being a programmer I rarely dive into teh plugin side unless it is absolutely needed :roll:
AND then I would have to NEED it really really bad :D
(;-) TP
Vmax549
Re: MDI Command Log
Postby Dan911 » Wed Jun 20, 2018 2:15 pm
Vmax549 wrote:Hi Dan, Did you use an onclick() or a ontype() function to gather data for teh MDI log ??
(;-) TP
//Called when the user enters text into the Textfield and it gets validated
//The labelnumber parameter is the ID of the accessed Textfield
//The bool Ismainscreen parameter is true is the Textfield is on the main screen and false if it is on the jog screen.
//The text parameter is the text entered and validated by the user
public void Textfieldtexttyped_event(int labelnumber, bool Ismainscreen, string text)
if (Ismainscreen)
if (labelnumber == 1000)
Re: MDI Command Log
Postby Vmax549 » Wed Jun 20, 2018 2:16 pm
OK that makes sense.
Thanks Dan
(;-) TP
Vmax549
Re: MDI Command Log
Postby dezsoe » Wed Jun 20, 2018 2:20 pm
Hi Balázs,
That's nice! Will it be available also in plugins?
Re: MDI Command Log
Postby Dan911 » Wed Jun 20, 2018 2:23 pm
dezsoe wrote:Hi Balázs,
+1
Re: MDI Command Log
Postby cncdrive » Wed Jun 20, 2018 2:29 pm
Hi Dan,
Yes, I've added them also to the plugininterface.
Re: MDI Command Log
Postby cncdrive » Wed Jun 20, 2018 2:30 pm
Hi Terry,
No problem. I had some freetime to add them quickly. :)
Re: MDI Command Log
Postby dezsoe » Wed Jun 20, 2018 3:10 pm
Fine! Thanks!
Re: MDI Command Log
Postby pupdogg » Wed Jun 20, 2018 10:07 pm
Wow, that was FAST! Thank you so much.
Paul Davis
5x10' CNC Router
UCCNC, ETH300, UB1, DMM Servos
pupdogg
