Custom screens/Touchscreens
Postby Mario Soto » Mon Jun 11, 2018 1:03 am
Hi Folks,
Is it possible to add keyboard key functions to a screen button for touchscreen applications?
Mario Soto
Re: Custom screens/Touchscreens
Postby dezsoe » Mon Jun 11, 2018 8:10 am
Hi Mario, Could you explain a bit what do you need and what do you want to do with it?
Postby Mario Soto » Mon Jun 11, 2018 4:32 pm
On a custom MDI screen (touchscreen ) I would like to eliminate the flyout keyboard and have the keyboard numbers right on the screen along with X /Y/Z.
I know it involves the keyboard source code.
Mario Soto
Postby dezsoe » Mon Jun 11, 2018 4:51 pm
If you need the numeric keys to enter data into fields on UCCNC screen, then enable the "On-screen keyboard" plugin. If you want to enter text also and use the MDI field, then it's another problem.
Postby dezsoe » Mon Jun 11, 2018 4:53 pm
But, you gave an idea how to improve the on-screen keyboard plugin. :)
Postby Robertspark » Mon Jun 11, 2018 6:09 pm
Edit the screenset file, it is not difficult, have a read of the manual below in my signature
Rob
UCCNC v1.2108 Macro Manual
Postby Mario Soto » Tue Jun 12, 2018 1:06 pm
Very helpful and I know if I keep trying with help I will get what I need.
This is for a 2 axis machine that only needs number keys and the letters x and y.
Even though the windows keyboard would work, it is not the best. Keys only used (on the screen) would be the better of the two.
Someone once said "The enemy of perfection is "good enough" ".
Thank you for the help so far.
Mario Soto
Postby cncdrive » Tue Jun 12, 2018 4:29 pm
You can use a macro to open the touch keyboard built into Windows:
System.Diagnostics.Process.Start("osk");
Postby Mario Soto » Tue Jun 12, 2018 4:49 pm
Mr. TP,
This isn't a router, in fact, it's hardly a machine.
It's just an XY back gage for a small punch press.
Here is one router I did for a Foundation we are working on.
It has a flat table and turning capabilities.
https://www.youtube.com/watch?v=KcZswyoQmIo
Mario Soto
Postby Mario Soto » Tue Jun 12, 2018 6:15 pm
So my thoughts for the x/y table is a touchscreen with an MDI input.
All that is needed is an X and Y DRO.
The user would input the X or Y dimension as an MDI instruction
The gage would then move to the location,
Having the letters X Y and 0-9 numbers on the screen would eliminate the annoying windows flyout keyboard.
Mario Soto
