Tool height setting macro
Postby andrewbishop66 » Mon May 21, 2018 3:57 pm
has anyone got a macro for the above using a tool height setter touch plate to populate the tool table that i can borrow/copy/steal
getting fed up with using a height gauge and doing math
Thanks andrew
andrewbishop66
Re: Tool height setting macro
Postby CL_MotoTech » Tue May 22, 2018 1:50 pm
If I ever get to a point where I'm not making stuff via Mach3 (where I have tool height function) and can focus on UCCNC for some time I will probably write this Macro.
Ideally I'd like the machine to go to a set tool change position and have a setting where tools in repeatable height holders will not be measured after tool change, but that complicates things further.
We will see how my work flow goes, maybe I'll find some time soon.
CL_MotoTech
Postby Vmax549 » Tue May 22, 2018 2:30 pm
What exactly did you want teh macro to do ?
(;-) TP
Vmax549
Postby andrewbishop66 » Tue May 22, 2018 5:07 pm
Hi Terry
I have a 3d taster that I know the height of 120.6 mm
id like to measure to my touch plate with that in manual mode zero something so that uccnc knows the distance from spindle nose to touch plate
then touch plate (connected to probe pin)
change tool run macro and have the tool length populate the tool table
change tool repeat
change tool repeat
if that makes sense
Thanks Andrew
andrewbishop66
Postby Vmax549 » Tue May 22, 2018 6:36 pm
Try this macro. It is off teh top of the head so test it carefully .
It should get you started. You can adjust the depth of Z probing in the macro. It is marked in the script.
//Macro M45 Tool Height Set
// Install Taster
// Z down to touch off
// Set Z Zero
// Install Tool to set
// Move down to less than 1 inch of touch probe
//From the MDI call M41 Qxx where xx is teh tool #, 1-96
(;-) TP
M45.txt
(1.19 KiB) Downloaded 51 times
Vmax549
Postby andrewbishop66 » Tue May 22, 2018 8:05 pm
You are a star
I would not have a clue where to start but tweaking I can do
I have done some visual basic in the past but that's it
Thanks ever so much I owe you a beer
Andrew
andrewbishop66
Postby andrewbishop66 » Thu May 24, 2018 11:04 pm
Hi Terry
just a question as I work in those horrible metric things mm
should I change the inches in the script to say 25 mm
Thanks Andrew
andrewbishop66
Postby Vmax549 » Fri May 25, 2018 12:29 am
Yes that will work for mm.
(;-) TP
Vmax549
Postby Robertspark » Sat May 26, 2018 6:30 am
andrewbishop66 wrote:just a question as I work in those horrible metric things mm
Haha, they are SI standard international units....
I believe that it's only the US that still uses imperial units, why I cannot fathom though
We (UK) still measure road distance in miles (why I cannot understand either) and fuel consumption in miles / gallon (imperial gallon that is (4.55 litre)... Not us gallon (3.75 litre)...).... But the fuel pumps deliver and charge in litres...
I've make some expensive errors in life, but this one always makes me smile and realise others have created bigger problems than mine in oversight error http://edition.cnn.com/TECH/space/9909/ ... metric.02/
Rob
UC400eth, UC300eth, UCCNC v1.2106, Neuron Lite
UCCNC v1.2105 Macro Manual
Postby Vmax549 » Sat May 26, 2018 12:36 pm
IF I remember correctly there was noise about teh UK going BACK to its old units of weight for commerce.
The US used the old saying IF it is not broke don't fix it.
(;-) TP
Vmax549
