Put my name on the list for lathe users
Re: Put my name on the list for lathe users
Postby ger21 » Wed Apr 18, 2018 11:00 am
I seem to recall that threading doesn't work in Mach4? but I could be wrong.
Postby Robertspark » Wed Apr 18, 2018 1:44 pm
Vmax549 wrote:It is odd to have encoder threading and NO TURN :o to use it.
Yes I second that .... You see this and then wonder, why not and how much is really required, given the cherry on the top (sync'd spindle motion) is aleady sorted and is likely to pull in all the M3 users who struggle with single PPR spindle sync.
https://www.youtube.com/watch?v=_PVYLCoFoK8
https://www.youtube.com/watch?v=25FtHEo4Ujo
Postby markcadcam » Wed Apr 18, 2018 5:15 pm
I agree with Vmax549. I think there are more lathe users out there then first thought. I for one, bought a Centroid Acorn lathe system (computer, controller software) for around $1200.00. After bench testing with it I decided to put it on the shelf and wait for UCCNC to come out with there lathe version. I've been using UCCNC for at least a year now with my Bridgeport and 5th axis trunnion table with absolutely no problems. I really like UCCNC. My 2 cents worth.
markcadcam
Postby Robertspark » Wed Apr 18, 2018 5:22 pm
There may be a lot more out there, but it's convincing them to migrate from mach3 with its screen set and turn wizards is it not?
Is there another hobby turn application out there other than artsoft / NFS?
What would be the rival products?
Postby markcadcam » Wed Apr 18, 2018 5:54 pm
Centroid Acorn. Check out their forum below. There are a lot of people moving away from Mach, not just for Mill. Lathe also.
http://centroidcncforum.com/viewforum.php?f=60
markcadcam
Postby markcadcam » Wed Apr 18, 2018 6:42 pm
I'll be happy with any screen shot that uses the UCCNC controller. I agree with the encoder threading function opinion. That's one of the main reasons I stayed away from Mach.
markcadcam
Postby markcadcam » Wed Apr 18, 2018 7:00 pm
Yes, only ones that support encoder threading.
Yes.
markcadcam
Postby Robertspark » Wed Apr 18, 2018 7:05 pm
I started fiddling with a screenshot of uccnc appearance.
Bottom line a screenset must be adopted by cncdrive and taken forward.
That way when functions and settings are developed they will be available on the new screensets
I know it may be a minor problem but if you customise a screensets it will become somewhat version static..hence some of the possible later fields and settings will not be available for you to use (unless you add the relevant fields and check boxes etc that is to the settings screens / tabs)
Postby Robertspark » Wed Apr 18, 2018 7:07 pm
Anybody try this out?
viewtopic.php?f=20&t=822
Postby markcadcam » Wed Apr 18, 2018 7:17 pm
I have not. Presently I do not have a way to test it.
markcadcam
