Hi All
thanks for the advice
Thanks for that Gerry I had looked at the post And decided I didnt know enough to mess with it will give yours a try on some simple holes and see how I get on
Thanks Andrew
cncdrive wrote:There should be no difference when loading g-code into the Default screenset or any other screensets.
A screenset is not influancing the g-code interpretation.
andrewbishop66 wrote:Ok the funny results happen when it is run in the default screen set
And I'm sure there is a large tool diameter defined for tool#8 when the same code was loaded with the default screenset.
Users browsing this forum: Baidu [Spider] and 7 guests
