2017 Screenset - Probing Issue
Re: 2017 Screenset - Probing Issue
Postby ger21 » Sun Jan 07, 2018 4:40 am
I was reading too fast, and missed the part about it being random.
You might want to try installing 1.2047, which is the current stable release.
You can post the whole macro.
Postby ger21 » Sun Jan 07, 2018 4:41 am
I'm guessing that it's the last part of what you posted that is where the crash occurs?
Postby spumco » Sun Jan 07, 2018 4:45 am
Now I'm really confused.
I tried a simple X-only pocket, and it just crashed after the X- move. It moved in the wrong direction this time. Usually it crashes by moving in an expected direction but not stopping.
Start position, then X+, then X-, then instead of moving X+ to center it moved (G0) in the X- direction and crashed.
Again, the probe trigger LED was lit, but the G31 (#24) LED was not lit.
spumco
Postby spumco » Sun Jan 07, 2018 4:49 am
This is three different macros that have resulted in a crash (inside pocket, outside boss, inside X-pocket), and crashes have happened at different points throughout the macros. All during G0 moves, however.
I'm going to update to 1.2047 right now and see what happens.
UPDATE - still happens with 1.2047. Same thing issues. First pocket cycle was fine, repeat was fine. Third crashed.
spumco
Postby ger21 » Sun Jan 07, 2018 5:21 am
Post the code so that Balazs can look at it.
I don't have an answer, and I haven't heard of this from anyone else, although I don't know how many have used it.
I never saw this when I was writing the macros, but that was a year ago, and there have been a lot of versions of UCCNC since then.
Postby spumco » Sun Jan 07, 2018 5:42 am
Thanks Gerry. I really don't know if the macro is at fault or something else.
Here's the inside pocket X-only macro. The X/Y pocket is basically the same, only longer, so I added it as an attachment.
// X Axis Pocket Probing Macro
int originalmodalmode = exec.actualmodal; // Modal mode (G0, G1, ...)
int originaldistancemode = exec.actualdistmode; // Distance mode (G90, G91)
double CurrentFeed = AS3.Getfielddouble(867); // Current Feedrate
string FeedOR = AS3.Getfield(232); // Current Feedrate Override
double CurrentFeedOR = Convert.ToDouble(FeedOR.Replace("%", String.Empty));
double FeedFactor = 100/CurrentFeedOR; // Feedrate scale factor is Feedrate Overide is not 100%
bool ZeroYN = AS3jog.Getbuttonstate(20540); // Auto Zero
double Frate1 = AS3jog.Getfielddouble(20333); // First Probe Feedrate
double Frate2 = AS3jog.Getfielddouble(20334); // Slow Probe Feedrate
double X1; //X axis Probe Point
double X2; //X axis Probe Point
double Xhit; //X axis Probe Point
double XCenter; // X Center Location
double XLength; // X axis Pocket Length
double XStart; // X axis Start Position
double Dmax = AS3jog.Getfielddouble(20335); // Probing Distance
double ProbeL ; // Probe Distance
double ZStart = AS3.Getfielddouble(228); // Current Z axis Work Coordinate
double XYClear = AS3jog.Getfielddouble(20337); // XY Clearance
double ProbeD = AS3jog.Getfielddouble(20338); // Probe Diameter
double Retract = AS3jog.Getfielddouble(20340); // Pullback Distance
double PlateOff = AS3jog.Getfielddouble(20341); // Plate Offset
string XC; // X Center String Value
string XL; // X Length String Value
int StrLength; // String Length
int Precision = AS3.Getfieldint(195) + 1;// Number of decimal places
string Dotstr = "."; // Decimal Separator
int DotLoc; // Location of decimal place
int DecLength; // # of decimals
if (Frate1 == 0) // Check Initial Feedrate
MessageBox.Show (exec.mainform, "Initial Feedrate is currently set to 0." + "\n" + "Set Initial Feedrate value and try again.", "Invalid Feedrate!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - Initial Feedrate = 0");
exec.Stop();
return;
if (Dmax == 0) // Check Probing Distance
MessageBox.Show (exec.mainform, "Probe Distance is currently set to 0." + "\n" + "Set Probe Distance value and try again.", "Invalid Probing Distance!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - Probe Distance = 0");
exec.Stop();
return;
if (XYClear == 0) // Check Probing Distance
MessageBox.Show (exec.mainform, "X-Y Clearance is currently set to 0." + "\n" + "Set X-Y Clearance value and try again.", "Invalid X-Y Clearance!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - X-Y Clearance = 0");
exec.Stop();
return;
if (ProbeD == 0) // Check Probing Diameter
MessageBox.Show (exec.mainform, "Probe Diameter is currently set to 0." + "\n" + "Set Probe Diameter value and try again.", "Invalid Probe Diameter!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - Probe Diameter = 0");
exec.Stop();
return;
if (Retract == 0) // Check Retract Distance
MessageBox.Show (exec.mainform, "Pullback Distance is currently set to 0." + "\n" + "Set Pullback Distance value and try again.", "Invalid Pullback Distance!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - Pullback Distance = 0");
exec.Stop();
return;
Frate1 = Frate1 * FeedFactor; // Scale Feedrate if FRO is not 100%
Frate2 = Frate2 * FeedFactor; // Scale Feedrate if FRO is not 100%
exec.Code("G90");
while(exec.IsMoving()){}
if (AS3.GetLED(37)) // Check Probe Input
MessageBox.Show (exec.mainform, "Probe Input is currently active." + "\n" + "Check connections and try again.", "Probe Active!!!", MessageBoxButtons.OK, MessageBoxIcon.Error);
exec.AddStatusmessage("Macro aborted - Probe Active");
exec.Stop();
return;
exec.AddStatusmessage(" ");
// Probe X+ axis
XStart = AS3.Getfielddouble(226); // Current X axis Work Coordinate
ProbeL = XStart + Dmax; // Probe Length
//exec.Code("F" + Frate1); // Set First Probe Feedrate
exec.AddStatusmessage("Probing for X+ Position...");
exec.Code("G31 X" + ProbeL + " F" + Frate1); // Do First Probe move
Xhit = exec.Getvar(5061); // Read the touch point
X1 = Xhit + ProbeD/2 + PlateOff; // Tool Center Position at X=0
if (Frate2 != 0)
exec.Code("G0 X" + (Xhit - Retract)); // Back away from edge
exec.AddStatusmessage("Slow Probing for X+ Position...");
//exec.Code("F" + Frate2); // Set Slow Probe Feedrate
exec.Code("G31 X" + ProbeL + " F" + Frate2); // Do Slow Probe move
} // End Slow Probing
exec.Code("G0 X" + XStart); // Rapid back to Start Position
// Probe X- axis
ProbeL = XStart - Dmax; // Probe Length
exec.AddStatusmessage("Probing for X- Position...");
X2 = Xhit - ProbeD/2 - PlateOff; // Tool Center Position at X=0
if (Frate2 != 0)
exec.Code("G0 X" + (Xhit + Retract)); // Back away from edge
exec.AddStatusmessage("Slow Probing for X- Position...");
// Calculate X Center and Pocket Length
XCenter = (X1 + X2) / 2;
XLength = X1 - X2;
// Convert X Center Position to String and reduce # of decimal places
XC = XCenter.ToString(); // Convert to String
StrLength = XC.Length; // Find String Length
DotLoc = XC.IndexOf(Dotstr); // Find location of decimal place
DecLength = StrLength - (DotLoc + 1); // # of decimal digits
if (DecLength > (Precision - 1))
XC = XC.Remove(DotLoc + Precision); // Trim extra digits from end, only if needed
// Convert X Length Position to String and reduce # of decimal places
XL = XLength.ToString(); // Convert to String
StrLength = XL.Length; // Find String Length
DotLoc = XL.IndexOf(Dotstr); // Find location of decimal place
XL = XL.Remove(DotLoc + Precision); // Trim extra digits from end, only if needed
if (ZeroYN) // Zero X axis if enabled
exec.Code("G0 X" + XCenter); // Move to X Center
AS3.Setfield(0, 226); // Set X axis DRO to new zeroed position
AS3.Validatefield(226);
exec.AddStatusmessage("X axis is now Zeroed at Pocket Center");
else
AS3jog.Setfieldtext(XC, 20347); // Write X Center Position to DRO
AS3jog.Setfieldtext(XL, 20345); // Write X Length Position to DRO
exec.AddStatusmessage("Pocket Length = " + XL);
exec.AddStatusmessage("Pocket Center located at X = " + XC);
exec.Code("F" + CurrentFeed); // Set Feedrate back to previous
exec.Wait(200);
if (originaldistancemode == 91)
exec.Code("G91");
if (originalmodalmode == 1)
exec.Code("G1");
M20537.txt
(11.73 KiB) Downloaded 845 times
spumco
Postby cncdrive » Sun Jan 07, 2018 1:02 pm
I have tested the macro with a UC100 and also with a UC300-5LPT and it works fine here.
Also I've checked the code through quickly and I do not see a problem for first sight.
Did you try to debug the issue yet with trying to see how the issue exactly happens?
I would check which code is exactly causing the issue.
From your description if I understand it correctly the X+ fast and slow probing both finishes OK and the X- fast probing also finishes OK and the issue happens somewhere after that, when the X- slow probing should happen, right?
So, you should investigate that code part a bit.
For example, do you see this message in the status field when the problematic movement happens? "Slow Probing for X- Position..."
It would be interesting to know, because if you do not see that yet when the problematic movement is ongoing, then what is causing the issue is not the X- slow G31, but the prior command, this:
So, if that's the case then I would put the "G0 X" + (Xhit + Retract) also into a Statusmessage to see what their values are and so what command is exactly sent to the UCCNC and go on from there with the debugging.
Or if you see the above mentioned message already when the problematic movement is happening then print the G31 command into a statusmessage, this one "G31 X" + ProbeL + " F" + Frate2
To see what exactly is the string which goes into the command when the issue happens.
However from the information you gave previously I guess that you do not see that message, because you said the Probing LED is inactive when the issue happens and from this I think the issue will be with the prior G0 command...
Postby ger21 » Sun Jan 07, 2018 1:35 pm
I would think the issue is with one of these moves:
But he's saying that it works some times, but not every time.
Postby cncdrive » Sun Jan 07, 2018 2:08 pm
Gerry,
I think one possible issue is if the result number is small and it goes represented in exponents.
In G-code exponent format is not correct, so if that happens that can cause issues, that the number for example 1E-004 could be understood by the UCCNC as value 1, while in reality the number is 0.0001.
Ofcourse this is just an idea, I did not see the issue, but the possibility is there that it could happen.
This is why I thought to print out the full commands into the statusfield to see what exact command is passed to the UCCNC executer when the issue happens.
Postby cncdrive » Sun Jan 07, 2018 2:29 pm
And if that's the problem then you could for example fix the number of digits in the number to avoid exponents format to happen, like:
string mynumber = String.Format("{0:F6}", originalnumber);
Return to Custom Screensets
