New Ideas for UCCNC features?
Re: New Ideas for UCCNC features?
Postby cncdrive » Thu Sep 08, 2016 10:19 pm
Vmax549 wrote:Hi ALL , I will start posting macro EXAMPLES when we get a MACRO section of the forum . Otherwise they will just get lost in teh jumble of posts. I would call it the "Macro ToolBox" section.
(;-) TP
Terry, I will check now how to give you permissions to you to create new forums, hopefully I'll find that menu item and then you could create new forums, e.g. for macros.
Postby cncdrive » Thu Sep 08, 2016 10:26 pm
Terry, check your permissions now please, you should be able to create new forums now.
Postby cncdrive » Fri Sep 09, 2016 1:27 am
Vmax549 wrote:HI CNCDRIVE, I do not see any options to do this . I even logged out and back in to make sure.
What do you see if you click the "Administration Control panel" on the bottom of the page?
There you should see option to manage forums and create forum etc.
Do you see that or not?
Postby cncdrive » Fri Sep 09, 2016 2:08 am
Cool. :)
Postby Battwell » Thu Oct 06, 2016 10:08 am
id love to have the homing code available to edit- so i could add homing to encoder z pulse. (i use servos)
i did mention it to balacz a while ago- but theres probably not many of us that would use it.
at the moment even with slow movement off the switch im only getting about 0.2mm repeatable which can show in work .
with encoder homing- like on my other machines i should get 0.005mm every time
Postby ger21 » Thu Oct 06, 2016 10:39 am
Do you mean like this?
exec.Callbutton(107); //RefHomeX
You could assign your index to one of the probe inputs, and do a probing move to the index? But then you'd probably need additional inputs?
Postby Battwell » Wed Oct 12, 2016 4:36 pm
Balacz told me homing was performed in the motion controller - not the pc.
What I would love is home onto switch, slow back off (as normal) then continue backing off until encoder index pulse and stop. Setting dro at this position is extremely accurate and not dependent on switch repeatability.
(It's how 90% of commercial machines are set up)
I use it on all my mach3 / galil conversions-,- always spot on
Postby medman007 » Thu Oct 13, 2016 10:06 pm
ger21 wrote:Rotary axis radius feedrate compensation
Has this been addressed yet?
medman007
Postby cncdrive » Fri Oct 14, 2016 5:47 am
No, the UCCNC does not support radius based feedrate control yet.
Postby medman007 » Fri Oct 14, 2016 1:54 pm
cncdrive wrote:No, the UCCNC does not support radius based feedrate control yet.
Thanks for the reply. Any idea when it will be supported? Once it has that feature and Gerry releases his screenset for purchase, I think the hobby market (and then professional with custom machines) will start switching over in droves. The uc100 has already eliminated quite a few headaches for me while still using mach. I would love to switch software as well.
medman007
Users browsing this forum: No registered users and 19 guests
