Toolpath View - Change Default View
Postby Robertspark » Sat Oct 28, 2017 5:18 pm
I may have missed something, but when UCCNC start, the Toolpath is always is in topview (button # 142)
Is there a way to change this so that when UCCNC starts it can be in Toolpath View Left (button # 141)
{this will be required for lathe screenset which I am now having a go at}
{I've not seen anthing in the profile or screenset which allows me to do this, I can do it by Macroloop, but thought it would need to be something combo-box based within the screenset, and pulled from the profile?}
Thanks as always
Re: Toolpath View - Change Default View
Postby Robertspark » Sat Oct 28, 2017 6:54 pm
Fixed via adding the following code to the constructor macro {called at startup and run once}
exec.Callbutton(141); // Toolpathviewleft  - Sets the toolpath to a left side look viewing mode.
Postby dezsoe » Sun Oct 29, 2017 1:39 pm
Rob,
It works only on startup. Any time you open a file, it will revert back to the original view. That's why I put into my QuickView plugin the lathe recognition. If you open a file which seems to be a file for lathe, it will change the view after the file is loaded.
Postby Robertspark » Sun Oct 29, 2017 1:45 pm
Thanks Dezsoe, yeah, I found that out when I loaded the gcode file.
I can add a macroloop to switch it back,.
Thanks very much, it should be a static profile setting really in my opinion
Postby Robertspark » Sun Oct 29, 2017 4:12 pm
this macroloop seems to work to solve the problem and reset the toolpath view for X&Z
if (val != exec.Getgcodefilename())
val = exec.Getgcodefilename();
while(exec.IsLoading()){Thread.Sleep(50);}
exec.Callbutton(138); // Set - Toolpathzoomcontents Zooms the contents in the toolpath viewer.
#Events
static string val;
Postby Robertspark » Tue Oct 31, 2017 3:11 pm
Hi Terry, long time no see hope you are well.
I managed to get it keep the view under gcode load, had not considered edit (yet)
I'm away from pc for a week (schools half term break)
Good to see you back
Return to Custom Screensets
