2017 - start into run-screen?
Postby CADdy » Fri Oct 27, 2017 4:47 pm
Hi all,
is it possible to start UCCNC (with 2017 screenset) to the run-screen? When I start UCCNC it will start to an "incomplete" settings-screen.
Thanks for infos
Peter
CADdy
Re: 2017 - start into run-screen?
Postby ger21 » Fri Oct 27, 2017 4:58 pm
Did you edit the screen? Either you did, or I made a mistake.
In the screen editor, navigate to the Run screen, and then save the screen from there.
UCCNC starts from whatever screen it was on when it was saved.
Postby cncdrive » Fri Oct 27, 2017 5:15 pm
When you edit the screen with the screen editor and if you save the screenset with the screen editor then the UCCNC checks through all the tab pages and saves the selected ones as selected, so the current view when saving will open up on next startups of the software.
So, as Gerry said, if you open the screen editor and navigate to the main/run tabe page and then save the screenset with the screeneditor then that will appear on software startups.
Postby CADdy » Sat Oct 28, 2017 11:55 am
Hi Balazs, Hi Gerry,
thank you very much! Now the start screen is that what I want :-)
Best wishes
Peter
CADdy
Postby CADdy » Sat Oct 28, 2017 12:10 pm
Hi Gerry,
ger21 wrote:Did you edit the screen? Either you did, or I made a mistake.
You didn't make a mistake, I've edited the screen a little bit:
I hope you're okay with that.
Many greetings
Peter
CADdy
Return to Custom Screensets
