2017 not saving kernel freq
Postby woffler » Sat Sep 02, 2017 1:26 am
I recently downloaded and installed the 2017 screen set all is well except it will not save the 50 kernel frequency ,it will save 25 or 100 but it does not want to save 50 for some odd reason .
Any one have a suggestion ?
woffler
Re: 2017 not saving kernel freq
Postby ger21 » Sat Sep 02, 2017 11:05 am
what motion controller do you have? I'll look into this when I get home from work later today.
Postby woffler » Mon Sep 04, 2017 9:39 pm
I have the UC400eth , its kind if weird .
woffler
Postby woffler » Mon Sep 04, 2017 10:07 pm
I also found another problem the tool number enter box on the run screen will not allow you to enter a tool number.
sorry about all this i love the screen set , i also have a question about setting tool # 1 .
If you use auto zero int. and you are setting up tool #1 you probe the tool to movable plate and then to fixed plate , why the move again in your G code to probe tool #1 again to the fixed plate you have just probed the same tool twice to the fixed plate.
woffler
Postby ger21 » Mon Sep 04, 2017 10:10 pm
I think I see the problem. Send me an email and I'll send you an updated version you can test for me.
Postby woffler » Mon Sep 04, 2017 10:31 pm
Email sent
woffler
Postby ger21 » Mon Sep 04, 2017 10:37 pm
Enter the tool number to the right of the Change Tool button. After pressing change tool, you should see the tool # in the "Tool#" DRO.
If the current tool # before you start is the same as the first tool, I don't think it will go and re-measure it.
Can you confirm that?
Return to Custom Screensets
