ger21 wrote:I'll add it to the todo list for the next version, but it'll be a while...
Talkiet wrote:I believe the newest test version has a home backoff parameter. From your previous comment I presume the new version will work with your 2017 screenset, but obviously there wouldn't be an input field for the backoff parameter.
Would there be an issue with setting the parameter using the default screenset and then loading your 2017 screenset (perhaps editing a file to bring in the backoff parameter values)?
Cheers - N
