MODBUSEZ Plugin
Re: MODBUSEZ Plugin
Postby tarnish1 » Mon Mar 27, 2023 3:25 am
[color=#FFBF00]
Mr.Hotwire wrote:Fulling DZB280...
I cannot for the life of me find the parameters for the registers. I am NOT able to get the spindle to move, but using MODBUSmaster I am able to see the connection to the VFD is functioning.
[/color]
Dont know if anyone monitors this thread nowadays, I have a Fuling dbz300 which is running via modbusez. the issue is that when 10000rpm is commanded in mdi the spindle only spins at 7500rpm. this is across the range of rpm. If I want 24000rpm I have to input 36000into UCCNC.
It seem like a multiplier or conversion factor within the Modbusez pluging. the VFD shows the correct rpm the spindle is turning at, IE 36000rpm UCCNC 24000 indicated at the vfd.
Any Ideas anyone?
other than tis issue modbusez works really well, Thanks for your effort Dan.
Phil
tarnish1
Re: MODBUSEZ Plugin
Postby manny » Tue May 02, 2023 4:02 pm
Hi Dan
Awesome plugin ! Could you maybe share the source code?
If not could you maybe make a new version with more fields "Amp Displays" to read more stuff from vfd like power, speed, amp, ......
manny
Re: MODBUSEZ Plugin
Postby Tobe91 » Thu Oct 31, 2024 9:47 am
Does anybody know what is happening, if there is any error or communication break down?
Does the plugin recognize this and stops the execution of the current program?
I didn't find any information about this in the thread.
Tobe91
Re: MODBUSEZ Plugin
Postby sebba » Fri Nov 01, 2024 5:54 pm
Tobe91 wrote:Does anybody know what is happening, if there is any error or communication break down?
I think it depends on your vfd settings
- YQWQ
sebba
Re: MODBUSEZ Plugin
Postby Corwax » Tue May 06, 2025 3:38 pm
UCCNC ModbusEZ dosen't save com port settings
It seems I've doomed. I've tried 3 different rs485 dongles. I've tried 3 different modbusez plugin versions (1, 14, 15). I've tried two different computers with UCCNC (one of them in demo mode). I've tried to run UCCNC as Admin.
Everything is absolutely, totally useless! The plugin did not save com port settings at all.
Definitely I've making something wrong, but I'm stuck. I don't have a clue how to resolve my issue.
Here is the video of UCCNC
https://youtu.be/DaCSWnGc5co
I would be very appreciated for any help/comments/solutions/hints...
Corwax
