Autoleveler Plugin.
Re: Autoleveler Plugin.
Postby lazy_23 » Tue Sep 03, 2024 8:53 pm
Hi to all.
I am not an expert and I spent two days trying to use the Autoleveler Plugin (AP), here is my setup:
Controller AXBB-E, UCCNC v1.2113, AP v 2.0049.
I use an inexpensive Touch Plate Tool as zero probe that is a cilinder hight 19.3mm (tool z offset).
My workflow: load in AP the toolspath g-code generated by Cut2D (post processor UCCNC(mm), the gcode seems ok), setting the AP as in picture
but the gcode sent to UCCNC have a huge z value in the cutting profile: after gatering all probe points, when the CNC begin to cut, the endmill go down to 193mm instead of about 30mm from the travel altitude [attachment=2Screenshot 2024-09-03 221959.png[/attachment].
I hope I was clear...
My question is: do I typed the right parameter in the Autoleveler Plugin (shown in picture)?
Would I use a newer version of the AP? (I tried AP v 3.031 but the tool z offset is missing)
Thank you in advance for any help
lazy_23
Postby soliman » Mon Sep 16, 2024 5:37 pm
cahit wrote:hi,
i want to try to add import gerber option to autoleveler. That's why I need help to get as many examples as possible to compare files. please help me send several so that I can study them. of course different generators.
thanks in advance.
cahit ates
c.ates@hotmail.com
Hello
I would like to know how setting for made PCB using UCCNC
soliman
Postby soliman » Mon Sep 16, 2024 5:42 pm
Would like to know how setting to work which PCB using UCCNC 1.2113 version any help please.
AutoLevelerCA 1.0048
soliman
Postby cahit » Tue Jan 28, 2025 7:51 pm
hi people,
i develop a new Autoleveler plugin. need a bit help with smooth lines (anti-aliasing).
my opentk code is:
GL.Enable(EnableCap.DepthTest) 'Enable correct Z Drawings
GL.DepthFunc(DepthFunction.Notequal) 'Enable correct Z Drawings
GL.Enable(EnableCap.Blend)
GL.BlendFunc(BlendingFactor.SrcAlpha, CType(BlendingFactorDest.DstAlpha, BlendingFactor)) <-- this does not work
need some help.
also attached last version with not 100% functionality. i am working on it.
any suggestion are welcome....
also i need different g-codes. please email to me so i can test it.
cheers
cahit
Postby cahit » Tue Jan 28, 2025 9:03 pm
i forget to upload the plugin
AutolevelerCA.rar
(122.77 KiB) Downloaded 432 times
cahit
Postby jjude » Sat Feb 15, 2025 2:59 pm
cahit wrote:i forget to upload the plugin
Not working UCCNC v1.2113
jjude
Postby cahit » Tue Apr 01, 2025 7:31 am
cahit
Postby cncdrive » Tue Apr 01, 2025 9:21 pm
Thank you Cahit.
Postby luki_v11 » Wed Apr 23, 2025 8:32 am
Hello
Thank you for your plugin. I am using your plugin together with a Stepcraft M1000 and the 3D Touch Sensor for bed levelling. It was working fine until today.
What did I do
1. Open GCode in Plugin
2. Send GCode to UCCNC
3. Start Probing with 3D Touch Sensor by Pressing Cycle Start
4. Remove 3D Touch Sensor by pressing the Open ATC Button
5. Press Cycle Start again
The problem
Usually here it would start with the milling operation, but today after one successful round, now it always goes to probing again.
Sometimes it goes to probing when i click the Open ATC Button, sometimes it switches to probing when I press Cycle Start.
I have tried to
- Restart UCCNC
- Restart Computer
- Powercycle CNC
- Tried with some older versions of my GCode
- I have tried to jump to the line after probing and run from there, but then the probing offsets were not applied.
Here are some photos and a video:
http://vision11.ch/share/temp/IMG_7953.MOV
https://vision11.ch/share/temp/IMG_7952.JPG
https://vision11.ch/share/temp/IMG_7951.JPG
The Probe-Sensor is working. I have checked in Diagnosis Tab.
Do you have any tipps for me?
Thank you very much,
Lukas
luki_v11
